Don, my unstyled B starts similar, but it has no petcocks. As far as how to start one, Im sure he will find IT DEPENDS ON THE TRACTOR as while many are somewhat similar, each has their own individual quirks n have their own best starting practices. What works well IN GENERAL for me REGARDLESS of which hand crank tractor is: 1) Shut them down by turning off the gas and let em run out of fuel which empties all the gas, then set the throttle open. 2) To restart, Turn the gas ON,,,,, give her a lil throttle (usually between just above idle to 1/2 or so, DEPENDS ON TRACTOR),,,,, ,,set the choke from 7/8 to full choke (depends on tractor) and crank her over a couple compression pulls or until she starts to show a lil vapor (NOT raw gas which can flood) out the petcocks if she has any,,,,, ,,,open the choke to between near open to 1/2 or so (depends on tractor),,,,, ,,she ought to start the next pull or two!!!!! !!!!! ! I feel this is one of those questions that has many varied methods n opinions, all as good as another, as it DEPENDS ON THE TRACTOR and theres no perfect way or perfect answer one size fits all lol. However, there are some fairly true and accurate things in general, such as, DONT OVERCHOKE N FLOOD (wet foul) the plugs,,,,, ,shut her off by turning the gas off and settign the throttle open,,,,, ,,have fresh clean water free gas and a clean air cleaner bowl,,,,, ,,,have good points n plugs (Replace if burned or pitted or carboned up or fouled),,,,, ,,,have good wire core wires,,,,, , THEN PLAY WITH AND EXPERIMENT AS TO HOW MUCH CHOKING AND THROTTLE POSITIONS AND SPARK TIMING AND CARB ADJUSTMENTS to best start the individual tractor. Thats what works for me, it will be fun to hear the methods n opinions of the gang as to what works for them, Im afraid theres no perfedct answer here cuz each tractor behaves a lil different, dependant upon many different parameters. God Bless yall John T
