Clooney, also need pto help
RichardSC
01-19-2005 07:03:17
I also have a 39 A with a twisted small shaft that I would like to replace with a larger shaft or just get a straight small shaft. Please email me with any info you might have. I only plan to use this tractor on a sickle mower from now on. Never again on a rotary cutter.
Thanks very much, Richard
RichardSC
01-19-2005 17:11:39
 Re: Clooney, also need pto help in reply to RichardSC, 01-19-2005 07:03:17
Thank you Clooney.
I will start looking for a shaft so I will be ready for hay this spring.
Richard
Clooney
01-19-2005 15:51:28
Richard, you are in about the same boat as Brian below.. I believe you�re �A� came with an A 571R power shaft (That�s the small splines)� You need to pull that shaft & measure it then go shopping..
About the same info I wrote to Brian holds for your early styled A (probably the same parts used)�
If you will settle for a smaller original see if Brian wants to part with his when he finds a later shaft.. I�m pretty sure his will fit your tractor (just compare shaft measurements).
Clooney
