Exhaust pipt height
txblu
01-19-2005 06:09:04
Hi Y'all.
Seems they put an extra 2x6 across my shop entrance that I hadn't planned on. The stack on the 4230 comes in at just under 3" clearance when I factor in a 6" slab.
Need to know how far above the "Soundguard" cab the exhaust has to be to keep the stuff out of the cab air inlets.
The exhaust pipe is the smaller diameter (2" roughly) as there is no turbo requiring the large pipe and it is straight vertical with a rain cap on it. So, the exhaust comes out at a pretty good velocity which gives it lots of lift.
Course I could excavate and put in a dropped ramp to get in; but then there would be a big gap under the sliding doors.
Thanks,
Mark
Jason Z in MO
01-19-2005 11:42:34
 Re: Exhaust pipt height in reply to txblu, 01-19-2005 06:09:04
I checked on JDparts.com and found the extension is 31.77". But now I realize you already KNOW how long it is...
You want to know how much you can safely cut off!
I guess you can also look at the problem like this... You have to cut off so much to safely clear the opening. Cut off only what you have too and see if there is an exhaust problem.
txblu
01-20-2005 05:42:00
 Re: Exhaust pipt height in reply to Jason Z in MO, 01-19-2005 11:42:34
Thanks,
That's the current plan. Thought I might touch on some experience where someone whacked it off too short and could tell me about it.
Mark
Jason Z in MO
01-19-2005 11:34:00
I can measure my extension when I get home.
If you haven't poured your slab yet you might consider... On my shop door I tapered the concrete off to give it a decent amount of fall from the point the door seals to the outside grade. The idea is as the rain hits the door and runs down onto the slab the water won't migrate under the door but roll off the slab. My door opening is 36' wide and I think we dropped it 1" with a 6" width.
Or you could always let the air out of the tires... :)
