DTLX carb for JD B
Loon Yi
01-18-2005 15:50:31
I have an early styled ('47, but before 201000 SN) B that has some parts I am wondering about. The carb is a DTLX 73 (the last digit isn't stamped clearly, it may be a 2). Haven't run it under load yet. Is this carb ok for this engine? Haven't opened the engine up to see if it's been bored or not either. Will the the 73 have enough adjustment for the slightly smaller engine in this model? The correct model is a DTLX 34, I think.
Clooney
01-18-2005 15:56:08
 Re: DTLX carb for JD B in reply to Loon Yi, 01-18-2005 15:50:31
Loon,, that last digit makes a big difference..
If it�s a 73 it should work good on your �B��
If it�s a 72 that carb is for an �A� & will work but not properly & be hard to adjust correctly as it is for a larger engine..
Clooney
