12 volt genny update
mattd
01-18-2005 15:13:43
clooney, john t thanks for the help. i think i almost got this figured out. i checked all of the wires and they were all right. i did the generator test by hot wireing it and it did not move. so i took the end cap off and the brushes were stuck. got them freed up and works good. then i took the vr off and called up the generator shop and told them the number off the vr and they said it was 6 volt. whew! i cant run the tractor to see if it works until i get my sediment bowl parts but as soon as i do i will see.
as for the mag. it does not make a click when turned over. i tryed looking at the serial number tag and i could barely make out x?041501. i couldnt see what the letter where the ? is. i looked at clooney recent post on J.D. Mag and in your picture the Wico X looks almost exactly like mine except where the text Wico X in red is, the wire from the ignition switch connects to. and also there is a steel plate with the 2 screws to connect wires to in the same area.
thanks for all the help. i think i got the handle of it
matt
mattd
01-18-2005 17:33:49
 Re: 12 volt genny update in reply to mattd, 01-18-2005 15:13:43
the mag does not click when turned over, and when the wire that goes to it is taken off there is no spark, and there is spark when it is on. which makes it a wico xb distributor? it is posotive ground. when i polarize it, and it polarized the right way now, will it be polarized wrong when i do it. and does it have to be running to polarize it. is there anyway to measure the amount of current coming out of the generator and into the battery using a voltmeter? thanks fot the help
matt
John T
01-18-2005 19:41:52
 Re: 12 volt genny update in reply to mattd, 01-18-2005 17:33:49
Hi again Matt, heres the answers in sort of the order you asked the questions.
1) Yes, if it does not click and theres no spark if the power input wire is removed or the ignition switch is OFF, as I said below, its probably a Wico XB Distributor.
2) No, if shes all hooked up n wired correct and youre at POSITIVE GROUND, when you polarize it as I described it will be polarized correct.
3) NO, dont have it running to polarize, do that FIRST.
4) YES AND NO. YESSSSS S With a Voltmeter its possible to tell if shes charging,,,,, ,,cuz at high RPM and assuming a good Gen and VR and a good battery, the voltage will rise from 6.3 to around 6.8 to 7, depending on the Gen and Battery condition. NOOOOO OO the voltmeter wont read the current, you need an ammeter for that (does tractor have one??) BUT if the voltage rises its dearing current and charging.
Youre welcome n thanks for the feedback, keep us posted n ask any more questions n we will try n help you.
John T
Clooney
01-18-2005 17:59:11
Matt,,, you say,,,
**the mag does not click when turned over, and when the wire that goes to it is taken off there is no spark, and there is spark when it is on. which makes it a wico xb distributor?
--Yes, it is a Wico distributor.. No click & it won�t spark with the power wire removed..
**it is posotive ground. when i polarize it, and it polarized the right way now, will it be polarized wrong when i do it.
--You don�t really know how it is polarized now, depends on how it was hooked up for the motoring test�..Yes it was built as positive ground but it will charge either way as long as it is polarized to the existing battery ground.. IT NEEDS TO BE POLARIZED AGAIN TO BE SURE..
**and does it have to be running to polarize it.
--NO, it MUST NOT be running..
**is there anyway to measure the amount of current coming out of the generator and into the battery using a voltmeter? --It would be hard to measure current with a voltmeter.. You can measure voltage while under a load though.. First--& warm it up,,,,,
Then, place the voltmeter across the battery posts,,,
Then, see what the battery voltage is at fast idle,,,
If above 6.8 volts it is probably charging,,
Then, turn the lights on & see what the voltage across the battery post�s is,,,
If, still above 6.8-7 volts it is charging pretty good.
If your ammeter is wired in the system correctly it should show a change also.. _____ _____ _____ _____ _____ _____ _____ __
��.Ammeter operation if wired correctly��
Lights on engine off----- -Show a discharge,,
Engine running at idle ----- Show a slight discharge to about 5+,,,
Engine running at fast idle----- ---Show a charge +5 to +15 amps or so depending on battery charge condition,,,
Engine running at fast idle, lights on----- ---Show a charge +5 to +10 amps or so depending on battery charge condition,,,
Clooney
John T
01-18-2005 15:44:36
Matt, youre sure welcome, glad we were able to get you this far, and thanks for the feedback.
1) Once the Generator is repaired and the brushes free, wire her all up as my post below explained (make sure BOTH Gen and VR are well grunded), then POLARIZE the Generator by temporarily attaching/jumping the Gens Field post to its case (leave all other wiring in place as is) and then flash/jump a wire momentary from the VR"s BAT terminal over to its ARM (or GEN) terminal (Or from VR"s BAT terminal direct down to Gens ARM Post) and you ought to get a spark, then remove all the jumped wires. She was originally POSITIVE ground, your battery still hooked that way???
BAT on VR to Ammeters load (NOT to battery or starter) side terminal. NOTE IT MUST SHOW HOT BATTERY VOLTAGE ALWAYS IF ITS WIRED RIGHT N THE AMMETER IS GOOD. Also, BOTH ammeter terminals should read hot. ARM (or GEN) on VR to Gens ARM post FLD on VR to Gens FLD Post Battery POSITIVE grounded to frame.
2) Then if she dont charge, see my post below for a complete test to see if its a Generator or a VR problem (No use repeating it all again here, its well covered below). But, if she will pass the motor test I described below, it ought to charge if the wiring is correct and the VR and grounds are all good.
NOWWWWW WW on that Ignition, if she really DOES NOT CLICK and theres those wires on it where you describe (that plate) and especially if the wire to it has hot battery voltage when you turn Ignition switch ON (place a test lamp there n see), IT SOUNDS LIKE A WICO XB DISTRIBUTOR????? ????? Thats NOT a Wico X Magneto, they require NO voltage ran to them but may have a kill wire up to dash BUT THEY JUST HAVE THAT SINGLE WIRE STUD. The XB Distributor looks similar, but it has a plate where the feed wire hooks !!!!! !
Remember a) A Wico X Mag should snap loud n sharp each 180 of flywheel rotation
b) If she wont run if that wire to it is removed (i.e. removes voltage from Ign switch) but runs if its atached and voltage to it,,,,, ,,,ITS A DISTRIBUTOR.
C) If she snaps and if she WILL STILL RUN with NO WIRES attached to it, ITS A MAG. A Mag dies if a wire to its external kill post stud is grounded out, maybe via a dash switch or direct on the mag itself.
Take a look at the Detailed Troubleshooting Procedure I posted below,,,,, ,,get the Gen wired up correct n Polarized,,,,, ,,see if that Ignition is getting voltage when the switch is ON (means its a Distributor NOT a Mag),,,,, ,,,see if she fires n see if she charges, if not post back your findings n any questions n we will try n help.
Good Luck n God Bless ya Matt
John T
Clooney
01-18-2005 15:39:15
Matt,, you just told us what we need to know..
Quote:--� in your picture the Wico X looks almost exactly like mine except where the text Wico X in red is, the wire from the ignition switch connects to. and also there is a steel plate with the 2 screws to connect wires to in the same area.�
{ �a steel plate with the 2 screws� }--That sentence tells us you don�t have a mag but in fact have a Wico XD distributor.. That Wico distributor looks almost exactly like a Wico X magneto but won�t click (as it has no impulse) & also NEEDS BATTERY power to it to work..
I guess to start with-- Try powering that power stud on the distributor case & see if it starts (or at least if it makes a spark).. If not, try cleaning the points & retrying it..
If it still doesn�t work we will have talk you through a Wico distributor trouble shooting.. Do you have a small hand held volt-ohmmeter & basically know how to use it?
On your generator,,,,, that hot wiring works real good for finding a generator malfunction & or stuck brushes.. Glad you got it motoring.. If the regulator is good it will probably charge..
Be sure to polarize it first..
To do that�.
Install a fully charged battery,,,
Then ground the generator�s (F) post to the generator�s frame,,,
Then locate the regulator�s terminal with battery power to it all the time,,
Then momentarily jump that powered terminal to the generator�s (A) post,,,
You should see a spark & if so remove the jumpers as it is then polarized.
Make sure you do this or you could easily burn the regulator up..
Let us know on that distributor???
Clooney
