Eric, When you say you havent added a Resistor yet, did it have one before???? Has it ALWAYS been a 12 volt tractor or was it converted from 6 volts???? Does the Coil indicate 6 or 12 volts??? Is she like original, i.e. Positive ground and which coil terminal is wired to distributor, the + or - ???? I ask all that cuz if its a full 12 volt coil NO BALLAST IS REQUIRED However, if its only a 6 volt coil and youre running it at full unballasted 12 volts, THE POINTS WILL BURN UP QUICKER AND THE COIL WILL OVERHEAT. If the coil gets warm when running its likely okay BUT if it gets so hot you can hardly hold your hand on it, it may be 6 volt coil and NEEDS THAT BALLAST so it wont overheat nor will the points burn up prematurely. If you measure the resistance of te coils low voltage promary between its lil + and - terminals, if its in the 1.2 to 2 ohms or so its a 6 volt coil n NEEDS A BALLAST. If it measures in the 2.5 to 3 to 4 ohms, its a 12 volt coil and NO ballast is even needed. IT HAVE ANY LABEL INFO????? ??? Now, the same set of points n condensor fires BOTH plugs, so if ine side is weaker, its a bad cap or rotor or a bad plug wire. You might try as posted above and swap plugs n wires side to side etc., TO SEE IF ITS A BAD PLUG OR A BAD WIRE OR THAT ONE CYLINDER THATS ALWAYS BADDDDD DDDD. Also, remove the plug wires but have their bare ends to within 1/8 or so from frame n crank her over and see if BOTH plug wires produce an identical hot BLUE SPARK. If one sides weaker, again swap wire to see if its ALWAYS that one side regardless of which wire (if ine sides weaker regardless of wires or plugs, cap or rotor problem). If one side is always a weaker spark, inspect the cap for cracks or carbon traces or bad rotor pickup terminals n look for cracks or gunk or carbon there n elsewhere in the cap. To see if the coil is making a good spark INDEPENDANT OF THE CAP N ROTOR, remove the coil wire from the cap (leave coil end intact) and turn her on n crank her over and see if teh coil wire makes a good blue spark when held to 1/8 inch away from tractor iron???? If she sparks good there BUT NOT out the plugs or plug wires, look at the cap n rotor again n make sure the wires n plugs are good, cuz we know the coil n points etc are okay!!!!! !!!! Its always good to start with fresh clean plugs and if the points have been filed or messed up and are burned or pitted or carboned up GET A NEW SET. In the meantime check the old ones and gap them and check the plugs n wires etc by swapping to see if its ALWAYS ONE SIDE that has a weak spark. IFFFFF FFFF the sparks good on BOTH but that one side cuts out, it may have low compresion or a leaky valve etc etc. It wouild be good to run a hot n cold compression check on both sides n if ones way lower,,,,, ,,,,you may have a cylinder versus any ignition problem. Summary; Insure good wires n plugs and if one sides ALWAYS BAD by swapping wires n plugs etc,,,,, ,,,RUN A COMPRESSION CHECK,,,,, ,,try fresh plugs,,,,, ,,,,,replace points if burned or pitted or carboned up,,,,, ,,,,, inspect the cap n rotor,,,,, ,,,,check the spark right out of the coil wire to see if shes at least good there???? You know at idle, she runs stronger on the left than right cylinder anyway !!!!! !!!!! The compression n wire n plug swap etc will tell us a lot. Let us know, Good Luck n God Bless John T
