39/40 B manifold B1313R scrap part
Jason Z in MO
01-18-2005 10:19:05
Wondering if someone has a junk manifold laying in their scrap pile...
I have a good manifold B1313R but the lower, rear #2 cylinder mounting ear is broken off. Let me explain, there is an upper ear much thicker that the bolt actually pulls the manifold down on the head. Where the manifold makes contact with the head is another ear that the bolt passes through. This ear is broken off. The only purpose I can think of for this ear is to prevent latteral movement.
Anyone have a junk manifold I could cut this ear off to weld to my manifold? I checked and no one is selling manifold ears on ebay... They say you can buy anything on ebay! :)
Maark
01-18-2005 10:48:47
 Re: 39/40 B manifold B1313R scrap part in reply to Jason Z in MO, 01-18-2005 10:19:05
You can take a thin jam nut, cut it to fit, round the edges, and then weld it on to give it a factory look. Been there, done that.
Mike M
01-18-2005 10:29:23
Just build one back on with a torch and brazing rod or maybe better yet get some cast iron rod.I have used an electric welder on cast manifolds before with nickle rod. Or you could just leave it off as it doesn't really do anything.Break the one off of the other side so they match ? say they made it like that.
Jason Z in MO
01-18-2005 10:49:27
 Re: 39/40 B manifold B1313R scrap part in reply to Mike M, 01-18-2005 10:29:23
Yeah, I thought about grinding it off... out of sigh, out of mind... But thought I would give a shot on here and see what I could find. Besides I assume the engineers put that on there for some purpose...
Can you rebuild it all back with weld and expect it to hold?
Once I get this fixed (weld it back or just grind it off) I need to have the ports planed but wanted to do the repairs first.
Mike M
01-18-2005 12:17:04
 Re: 39/40 B manifold B1313R scrap part in reply to Jason Z in MO, 01-18-2005 10:49:27
You may want to plane the ports first as welding may make a hard spot to catch on and break it back off.It depends on the method used to fix it. That electric welding can hold up good. I fixed a pretty good hole in an LA manifold and a complete center break thru on the 4020 gas both still holding after a lot of years. I have never used the torch and cast iron filler rod method yet.I have heard that this is the best way.
