Hey Guys,I finally got all the of valves/push-rods out of the bores/chambers[except pressure-relief valves]. Some of those valves took tapping with a wood dowel & hammer and many bottles of PB plaster, WD-oil, then removel with needle nose pliers and a lot of elbow-grease. Here's the million dollar question for anyone!! Since over 50% of the valves removed were absolutely frozen via rust & red-sediment, I can see by looking down into the pipe-plug holes that one of the two pressure relief valves has rust on the rod. I know that by removing these valves the service manuals start talking some real detailed work and adjustments. I am afraid that it I do not remove/clean these, like the other stuck valves, that if these do not work, then all the other work I have done is for absolutley nothing, along with about $200 in parts. Has anyone ever taken out the pressure relief valves before and replaced them successfully without have to go through major anguish in making a myriad of post-installation adjustments? Any and all advice would be greatly appreciated. It would be most disappointing to completely reassemble the TOM unit not to have it work because the P-relief valves are stuck, then have to shear those pins again and go through the entire process of disassembly again...guess the girls and wife are not going to see any BBQ on the weekends for quite awhile. Thank you very much for your advice, tom
