Jason, it would help to know what tractor your are working on but they are basically the same except the gear & shaft sizes.. Obviously a press works best but as you found out that big gear won�t clear in some instances.. I have a 50 ton press & a set of adapters that will clear most gears but have also done many with a GOOD 3 jaw puller.. First the puller MUST have deep enough jaws to fit around the mag drive flange & even then it might be hard to get the puller to clear the flange & engage the jaws properly.. (you will probably have to depress the spring slightly to get the jaws in behind the flange)
If your puller fits the above requirement,,, install the puller,,, then use a large hose clamp to run around the puller jaws to help the jaws stay engaged� Then tighten the puller to just before the jaws spring off the flange.. Then rap the end of the puller with a hammer.. If the flange moves you are in luck,, if it doesn�t use an acetylene torch with a small welding tip & heat the flange hub (hot & fast).. You want to heat that flange hub fast before the spring gets hot (use an oil soaked rag to cool the spring if needed (Caution: don�t heat the spring any more than necessary).. Then rap that puller with a hammer again.... Just watch the spring that you don�t overheat it (the puller jaws should help hold it away some).. Don�t worry about the shaft expanding also as the flange is larger so will expand more than the shaft will.. If you must heat it with a propane torch set the shaft in a bucket of water with the spring below the water level so you can slow heat the flange without overheating the spring. I have removed quite a few this way when I didn�t have a press handy & have always managed to get them apart.. Patience & heat will persist.. (almost every time) If you have a bearing separator you can also clamp that on under the flange then use a large 2 jaw puller on the separator & pull it loose that way also.. Or set the shaft inside a large pipe with the separator on top of the pipe & press it apart that way. Clooney
