Early Styled B front wheel Hub
Jason Z in MO
01-18-2005 09:24:04
I pulled the front hub off my B. Found the inner bearing race has worn the hub out of tolerance.
What is the recommended solution from keeping that race tight and not spinning in the hub? Or do I need to find a replacement hub?
Clooney
01-18-2005 13:58:33
 Re: Early Styled B front wheel Hub in reply to Jason Z in MO, 01-18-2005 09:24:04
Jason, there are a few ways,,
One is to peck all around the inside of the hub bearing mount area with a series of center punch marks to allow the race to press in tighter..
Another is to use Loc-Tite stud & bearing mount to set the race in with.. That works great but the race & hub MUST be spotlessly clean & free of ALL oil & grease.. It also helps to punch per above first to center the race in the hub when driven in..
Clooney
Jason Z in MO
01-18-2005 14:38:06
 Re: Early Styled B front wheel Hub in reply to Clooney , 01-18-2005 13:58:33
Clooney,
I have heard about the trick with the center punch but there is a noticable (hang your finger nail on it) lip from the wear area to what the bore should be. I will slip the race back in an measure with a feeler gauge.
I was afraid the metal displaced with the center punch would just get smashed flat again once the weight of the tractor is back on the race.
How much gap will the Loc-Tite product fill? Maybe this with some shim stock?
Did some one say you were writing a book???
I'll pay!
Clooney
01-18-2005 15:04:32
 Re: Early Styled B front wheel Hub in reply to Jason Z in MO, 01-18-2005 14:38:06
Jason, if you have a large gap the punching alone won�t hold that bearing race centered..
Loc-Tite Green 680 will fill & hold a gap of .015�..You will need heat to get that race out in the future though..
There are Loc-Tite products that will fill more but are more for a temporary repair & than long term repairs..
You could also use a product like JB weld as that would probably work to hold that slow speed bearing race..
Clooney
Jason Z in MO
01-18-2005 21:08:38
 Re: Early Styled B front wheel Hub in reply to Clooney , 01-18-2005 15:04:32
Clooney,
Oh, I am a big JB Weld fan!
I tried to slip the new race into place but I didn't want to drive it past the good part of the bore to only have to remove it later. Funny the old race has a nice smooth outer surface. The slot in the hub where it rides looks like it was machined there. I would expect to see some scaring or damage...
If I drop the old race in square it falls home. The new race is .002" larger than the old. With the old race in place and using two feeler gauges I can slip .003" on one side and .004" 180 deg apart for a total of .007" slop. Minus the .002" and divided in half; there is .0025" around the circumference.
JB Weld or Loc-Tite 680 sounds like the best solution.
