Fuel sediment bowl - A
Walt in Jaxn Tn
01-17-2005 22:40:19
Got a problem with the fuel shut off on the origional sediment bowl on my "A". Where can I get a sediment bowl with 3/8 male npt inlet and 1/4 male npt outlet so that I can use the 3-way selector valve. My origional shut off will not "shut off" the fuel flow, only slow it down. John Deere had these origional shut offs 14 years ago but wanted over 100 dollars for them. --Walt--
Pat Browning
01-23-2005 21:30:51
 Re: Fuel sediment bowl - A in reply to Walt in Jaxn Tn., 01-17-2005 22:40:19
Try Greg Stephen at Stephen Equipment, 7460 E Hwy 36, Franktown CO 80116. Call (303) 663-5246.
Henry J
01-18-2005 06:42:06
Walt
I don't have any idea about how your bowl looks and how the selector lashes up to it or is a part of it.
The specs you gave on the threads basically should match a common Tillotson fuel bowl/shutoff that should be available at auto parts stores (NAPA/Carquest).
The thread info you gave is the same as the threads on my 420 as I just bought a tap to clean out the threads in the fuel tank.
I hope I havn't given you a bum steer, but it won't cost to check.
Kinda following Clooney here and saying been there and done that, but not on an A.
