G rock shaft
sj
01-17-2005 18:13:45
Putting the rock shaft back in my 51 G and noticed an arrow on the end of each shaft. Which way do these arrows point when the piston is forward, as I'm not sure it was in correctly in the first place. There didn't seem to be any tension on the spring, and my manual doesn't say anything about it.
Clooney
01-18-2005 06:26:46
 Re: G rock shaft in reply to sj, 01-17-2005 18:13:45
sj, I think those arrows are there to tell you what position the rock shaft is in so you know what position the shaft is in when you install a rockshaft mounted implement,, so pointing up would probably in the raised position & pointing rearward or rearward & down would be with the piston forward.. I guess it really doesn�t matter as long as you remember where the arrows point with the rockshaft raised & where the arrows point when lowered..
Clooney
