How to tighten nut on crank/clutch
kurt_JDB
01-17-2005 15:25:02
I am getting into the clutch on my "51 JD B. I have got the big nut off at the end of the crank. I was unable to get the driver disk off because I did not have the right puller. (next week i"ll get or make one)
Since I did not complete the project I decided to put it all back together. I put the nut back on, and reasembled and adjusted the clutch. I then tried to tighten the nut. All I managed to do was rotate the engine and move the tractor. In gear with the brake set. Maybe the brakes are no good.
Anyway, how tight does this nut need to be? what is a good way to tighten it?
Thanks, Kurt
nc jd guy
01-17-2005 18:13:42
 Re: How to tighten nut on crank/clutch in reply to kurt_JDB, 01-17-2005 15:25:02
I had to pull mine last week. Just made one from an 18" long piece of 1/8" x 1" bar stock. Just bend it around a bolt to make a big flat U. If you have a welder, box the open end in, if you don't just drill a 1/4" hole at the open end and put a small bolt with a nut in it to keep it from springing open.
Clooney
01-17-2005 16:28:57
Kurt, an impact wrench works about the best but you could also use a long hand wrench & hit that with a large mallet or even a hammer,,,,, or block the flywheel to hold it & then use a hand wrench (breaker bar) .. It doesn�t have to be real tight but must be tight enough to not come loose..(I usually use a little 290 Lock-Tite on those clutch driver bolts to make sure they stay tight)..
If your clutch pulley brake is working that might even hold it if someone pulls that tight while you put a wrench to that bolt..
Clooney
Kurt_JDB
01-17-2005 17:43:07
 Re: How to tighten nut on crank/clutch in reply to Clooney , 01-17-2005 16:28:57
Thankyou, I will try your suggestions. Oh, Yeah it"s a bolt, not a nut. Shoot, I guess I put my pants on backwards this morning.
Kurt
