720 diesel power steering leak
gpuller
01-17-2005 13:11:22
The power steering on my 720 is leaking and I"m not sure why. The oil is coming out the vent/dipstick. At first I thought it was building pressure and forcing it out the fill. I cleaned the vent in the dipstick and still oil will bubble out the vent. I then checked the oil level and it was way over full. I drained it down to the proper level and within a couple days it was bubbling out the vent and over full again.
Were is the extra oil coming from? Is there seals in the pump that have gone bad and is sucking engine oil from the governor through the fan shaft? Other than making a huge mess the steering works fine. I have the tractor apart right now and it would be a good time to fix this. Has anyone else had this problem?
Clooney
01-17-2005 14:11:43
 Re: 720 diesel power steering leak in reply to gpuller, 01-17-2005 13:11:22
gpuller, if it is actually gaining oil in the P/S reservoir there is only one place it can come from�That is the rear oil seals on the P/S pump.. There is a double facing seal on the rear of the pump (2 separate seals to replace with) & that could allow oil to be sucked from the fan shaft tube..
If it is just getting air in the system & raising the oil level or forcing oil out then we�re back to those rear pump seals again or it could be sucking air from the front pump seal also or sucking air from the P/S return line or fittings.
If you pull the pump,,, watch that the fan shaft couplings don�t pull forward with the pump as those are a real pain to re-install.. Also check the pump shaft splines for wear as those are usually found about worn out..
If you have a severe oil gaining problem you might also check out the fan shaft vent pump as those tend to push oil when they fail..
Clooney
Clooney (whoops)
01-17-2005 14:14:37
 Re: 720 diesel power steering leak in reply to Clooney , 01-17-2005 14:11:43
Sorry I didn't see it's a diesel.. No fan shaft vent pump on the diesel but all the other is the same..
Clooney
