50 transmission
Roger D
01-17-2005 12:17:51
Firstly I have a 1954 JD 50 which slides out of 1ST gear when pulling hard. I can"t hold the shift lever in gear. I have the Parts book, service manual, and IT book but am still in doubt of what to look for first when I take the transmission cover off in the Spring. Ant help would be appreciated.
Thanks, Roger
buickanddeere
01-17-2005 17:13:18
 Re: 50 transmission in reply to Roger D, 01-17-2005 12:17:51
Many of the transmission parts were common or will fit from a styled B to a 530, lots of pieces out there. The parts on a B were likely less stressed. We found a twisted shaft and a chunk out of 2nd/5th gear on of the 50's here . That and a couple of marks on the tractor suggests it perhaps was ran into, or ran into something solid while in 2nd or 5th gear. While it's apart have a look at the shaft/bearing/housing in the 1st reduction cover. They can wear that housing bore oval.
Clooney
01-17-2005 15:25:55
Roger, I pretty well agree with Chuck on the cause only will add you could also find a twisted sliding gear shaft or severely worn 1st-3rd sliding gear�s inner splines.
That later shifter lock (Deere even offered a service kit) is a good addition but if you can't even hold it in gear with the shift lever all that will do is place a very high load on the shifter & shift fork & probably break it eventually.. With that much force trying to move that thing out of 1st gear you really need to find the problem.
You will need to pull the trans top cover & grab the sliding gear shaft as well as all the shafts & look for excess lateral & vertical play due to bad bearings,, then move the 1st-3rd gear around on the shaft & see how loose it is.
I have even seen the main case worn oblong in the bearing holes so look there also..
You have wear in that trans (probably lots of wear) & the harder you pull with it the more apt you are to have additional problems..
Keep in mind that once you open that trans up you could have some pretty good money into it as even just replacing bearings can easily run into hundreds of dollars with possible gears & shafts adding a lot more..
Clooney
ChuckW
01-17-2005 14:39:35
I have seen this problem many times. The 1st & 3rd drive gear wears a groove in the top spline, normally the tractor was used in 3rd gear the most, plowing, general field work, discing, etc. Since it wore a slight groove it will tend to walk out of line and in a rear hard pull will squirt out. I would recommend finding a better upper shaft less wear and add the locking shifter used in the late model 50's. They had a severe problem with this and this holds the shifting collar in place till a side movement of the level releases. I've put several in and have one or two left. They also added this feature to the 4/6 position on the later series. You may also check for a worn bearing on the end of the shaft.
