JD 530 Crankshaft Trouble Please Help
Phil
02-13-2004 19:17:40
I am in the process of rebuilding my JD 530 and on the belt pulley side of the engine the crankshaft is wore about .010 undersize on the main bearing journal and needs turned and a new bearing installed. Problem is JD only lists a max .004 undersize in the parts book, and my crank will probably be .015 or .020 undersize after it is cleaned up. Does anyone know where I can get a main bearing that will work with a crank turned .015 to .020 undersize. Machine shop book listed them but they were not advaiable when the guy at the machine shop started calling around. Any solutions to this problem greatly appreciated. Thanks
Phil
02-14-2004 15:58:24
 Re: JD 530 Crankshaft Trouble Please Help in reply to Phil, 02-13-2004 19:17:40
Thanks for all the feedback, when I talked to my dealer they could not tell me how much material was there to machine out and if I ordered it and couldn't use it they wanted to charge me $20.00 to restock it. Don't know why they can't be of anymore help considering i probably bought over $3000 worth of parts since the beginning of the year for all the different projects I have on the go. Thanks Again.
Phil
Tyler-MO
02-14-2004 15:26:06
Phil,
I just got done with my 520 crank (same as 530) not too long ago. I know that they turned my RH main journal some and the stock bearing was turned out to match. I was under the impression that there was several thousandths of an inch oversize to allow for this. I would recommend going to your JD dealer and having them call their Parts Expediter to get exact specifications on the replacement bearing. The one I got was current production and came with the new JD logo on it. I would tend to think that the new bearing may just be like the other guy said (.060) undersize to allow for a lot of crank turning and to satisfy nearly anyone that would need the part. But the Dealer should have not mind calling their parts coordinator/expediter as they can give exact details and even fax the original engineering spec sheets if need be. Let me know if you need any help. I wouldn't mind at all. I'm working at a JD dealer MWF and Sat. From 1-5 CST on MWF and 8-4 on Sat. Give me a call at 1-877-729-7720 toll free and I'll do it for you if you like. Good luck and if you need any of my hard learned lessons with my 520 restoration just feel free and I'll gladly share them with you. Tyler in Missouri
Clooney
02-14-2004 09:01:10
Phil, Deere doesn't service those undersized bushing housings any longer.. I believe what you need is the B 3736R undersized bushing. That is the bushing only & it comes [at least came] in about .060" undersized,, then when it was pressed in your housing it was bored out to fit your new crankshaft main journal size.
~I haven't bought one for a few years so maybe Deere no longer stocks that either.. You might have your local Deere dealer try that number, then have them try it with the R dropped, then try a dealer search on that number as maybe some other dealer has it.
~If you draw a blank at Deere give me an E-Mail, put " 520 bearing" in the Subject line so I can find it as I have about 3 pages of inbox E-Mails at the moment.. I will then send you a few places & phone numbers to try for that bushing [or the aftermarket equivalent]...
[email protected]
Jarrod
02-14-2004 06:53:36
Get them to weld it up and then turn it back down if all else fails.
