B sheet metal
Daniel Chestnut
02-13-2004 18:51:41
I came home early from college today and got my B out. Thats when I noticed the top radiator hose was leaking. I drained the antifreeze out, got the old hose off, and tried to put the new one on, but I couldn't get it on. I thought I'd try taking off the sheet metal and maybe I could get closer to getting it on. I've got all of the hood loose and the gas tank. Whenever I try to take off the hood, the gas tank wants to come off with it. I took off the two rear bolts that holds both sides of the hood to the gas tank. There was two nuts to take off that held both front sides of the hood that I took off. This is where the gas tank really seem stuck to the hood. Can someone tell me what is keeping me from taking off the hood? Thanks in advance.
ravgardner
02-14-2004 06:19:40
 Re: B sheet metal in reply to Daniel Chestnut, 02-13-2004 18:51:41
I ususally leave the tank(s) in the sheet metal. I take off the fuel lines and all the other control levers and steering column etc. Then lift the sheet metal and tanks off. Hope there isn't much gas in the tank! That hose is difficult to install. Perhaps use dish soap to "lube up" the surfaces so it will slide on. I needed to unbolt the radiator and lean it forward to make some room so I could slide it in place. Good luck guy. I hope some else has a better way. I'd like to find one!
old
02-13-2004 19:49:16
There are 2 more bolts/nuts in the middle sort of hard to see, had the same problem with my B
