420 TRANSMISSION WAYNE IN TN AND OTHERS
HAL
01-17-2005 06:54:26
I am getting ready to teardown my sons 420 transmission and replace the "cluster gear"(the one in the very bottom that EVERYTHING else in the transmission case has to come out to make room for it to come out). My question is can this not be accomplished by removing only one of the final drives from the case? I was removing the gear from a donor rearend and transmission last night and by the IT manual it led me to remove both final drives, but i cant see why only one side wouldnt be enough to get the ring gear out of the way, I did the removal in the floor of the shop and wasnt planning on removing anymore than necessary those final drives are pretty awkward and heavy to handle any other help or advice is appreciated. thanks Hal
Hnery J
01-17-2005 10:22:44
 Re: 420 TRANSMISSION WAYNE IN TN AND OTHERS in reply to HAL, 01-17-2005 06:54:26
Hal
On the W model the pinion shaft that drives the small gear in the final drive slides into the differential hub and into one of the spider gears in the center, as I recall. So on a W, I would guess it would be impossible without pulling both finals.
I probably should have not commented since I am assuming the differential setup in the T operates in a similar manner.
Wayne in Tn.
01-17-2005 08:10:13
Hal, you don"t say what model 420 such as S T U V W. But the last one I was into was a 40W and the best way was to remove both finals and get the transmission case on a table for eaiser work. One thing for sure is the rear cover has to come off and the PTO shaft removed. So to answer the question, I would suggest removing both finals, then you can inspect all bearings and replace seals. Like I said, I am not sure what model you are working on, but you may have answered your own question, by tearing down the donor tractor.
HAL
01-17-2005 08:37:03
 Re: 420 TRANSMISSION WAYNE IN TN AND OTHERS in reply to Wayne in Tn., 01-17-2005 08:10:13
Thanks Wayne, it is a 420T with factory wfe, also my parts cd shows a transmission and final drive gasket set for C,S,U,I, but no T any ideas? Is the gasket where the final drives bolt on going to be the main differences between the kits? According to the book the T's gasket is a different part# from any that is shown in the kit
Wayne in Tn.
01-17-2005 15:33:08
 Re: 420 TRANSMISSION WAYNE IN TN AND OTHERS in reply to HAL, 01-17-2005 08:37:03
Hal, yep that T will have different finals. As to the big gasket, I just cleaned the surfaces good and ran a small bead of silicone and did not use any gasket. It worked fine for me, no leaks.
