Ethanol Blend Gasoline?
leon
01-17-2005 05:04:59
I try to never use ethanol blend gasoline in my small engines and old tractors. Now there is talk in our Iowa state legislature of new legislation would that require all gasoline sold in the state contain ethanol. What are you folks in Hawaii and Minnesota, where I understand you already have similar laws, doing for fuel in the oldies?
GERRY G
01-18-2005 11:06:17
 Re: Ethanol Blend Gasoline? in reply to leon, 01-17-2005 05:04:59
IF YOU ARE ONLY GOING TO PLAY WITH THE TRACTORS LIKE ME I USE AVIATON GAS. IT IS 100 OCTANE LOW LEAD AND I PAY ABOUT 2.58 PER GAL. I USE A 100 TO 1 2CYCLE OIL FOR VALVE LUBE.
#6BinMN
01-17-2005 07:52:54
We can still get the non ethanol gas here in MN. Shell here in town has it. But the sticker on the pump says it is for use in small engines and pre 68 cars and trucks only. I use it in my skid loader, mower and other small engines.
Dave - Ia
01-17-2005 07:42:13
I have been using the ethanol blend in my tractors for several years now and have not had any problems other than maybe having to clean the sediment bowl out a couple of times when I first made the switch. I did have a problem with a water transfer pump with a 3.5 horse Briggs engine. A rubber diaphram in the carb stretched and I had to replace it. The operators manual for this engine said not to use ethanol. Why not use what we produce?
01-17-2005 06:54:52
The only thing I won't run alcohol blends in is a two stroke. Leans the mixture and disolves the lube oil to some extent. I have to wonder why people put the cheapo 87 alcohol blend gasoline in their high performance snowmobiles. It must be to keep piston manufactures and machine shops busy boring cylinders. The detonation from low octane,leaner mixture and hard running. Along with the cheapest two stroke oil that may have been blended for cool running outboards.
CMB
01-17-2005 06:53:26
I've used 10% ethanol blend almost exclusivly in all my vehicles & two cyl tractors for over 20 years, and have yet to experience a fuel related problem. Since I am a farmer, I try to use ethanol just on principal-makes another market for the corn I grow. I have two new ethanol plants within 10 miles of where I live. One went "online" in November,& the other is scheduled to start up in Febuary. Between them they will be grinding about 60000 bushels of corn a day, seven days a week, every week. There is also a local hog feed plant that grinds 30000 bu. per day five days a week. As I understand it these three plants will be using more corn than is produced in my home county,& we are one of the top corn producers in Iowa. Hopefully this will help our local markets.
Clooney
01-17-2005 06:23:28
Leon, your old engines & tractors should run ok on the blend & depending on the % ethanol blend in the gasoline shouldn�t cause a starting problem unless real cold out..
Probably the problems you will encounter are some cleaning of the fuel systems so could be plagued with plugging carbs, sticking check balls in the small engines, & if any of your old engines have old fuel tanks you could find pin holes in the bottom that have been glazed over for years with old fuel varnish..
I have had some problems with my hit & miss engines with alcohol laden fuel as it oxidizes the fuel system check balls so they stick & won�t draw up any fuel after sitting for a few weeks. I have been converting them all to brass check balls as I pull them apart to clean them & that seems to be the answer.. (even stainless balls seems to stick)
I have a friend that is running his small engines on Coleman Lantern fuel as that is closer to the old fuel in the day those engines were used� I have been thinking of running a few of mine on propane as that seems to be a coming trend..
You have probably already used some ethanol blend gasoline without even knowing it as some gasoline stations buy black market & don�t label the pumps to reflect that or in some cases don�t know or care what is dropped for fuel..
Clooney
Henry J
01-17-2005 06:11:37
Leon
I use whatever regular grade that comes out of the pump. Have never put the effort into hunting down "real" gas. I do spike the gas that sits around that I use in the smal engines and JD with a little outboard two cycle oil.
Mike M
01-17-2005 05:45:00
I'm sure I have used and still use it and I can't say that I have had any problems with it. What kind of problems have you had with it ?
