1979 2040 Oil Leak
Blake Simpson
01-17-2005 04:13:19
My 2040 has been leaking oil from the weep hole below the bell housing for some time, not a real big leak but enough that it bothered me, so I split it this weekend and the clutch is toast as I suspected, and I have already pressed in a new rear main seal with the correct tool so I should have the leak at the rear main seal taken care of, but when I split it the whole inside of the clutch housing was coated with oil and could not tell if it was engine oil or hydraulic oil, I want to make sure that I don't have to do this again in the near future so is there any other seal in the transmision that I can change with the tractor split at the clutch housing that could allow hydraulic fluid into the clutch housing, when I went to jd to get my rear main seal and all the seals I thought I would need he said there was a seal between the pto shaft and the drive shaft that I could change so I got the seal but there is no way that the seal he gave me will go between the two shafts at least it will not go in from the front of the transmission.
KLM
01-17-2005 17:48:11
 Re: 1979 2040 Oil Leak in reply to Blake Simpson, 01-17-2005 04:13:19
On a 2040 you would put the tractor back together without the clutch in it then you split the transmission just to the rear of the steering column. This is where the shifters and Pto engagement are. Then you pull the pieces out. You will need to drain the trans. oil first before splitting (if not=big mess). Once you repair the rear end you put it together and split the clutch housing to install the clutch. Before completing the job.
blake simpson
01-17-2005 19:40:03
 Re: 1979 2040 Oil Leak in reply to KLM, 01-17-2005 17:48:11
can I split it behind the gear shifters after I have put the clutch back in and replace the seal in the transmission I really don't want to have to split it at the clutch housing again if at all possible thanks
david val
01-18-2005 02:00:23
 Re: 1979 2040 Oil Leak in reply to blake simpson, 01-17-2005 19:40:03
you can finish up the work in the clutch area and then split at the tensmission for seal replacement. remember: there are two bolts to be removed for splitting under the shift lever cover, there are two seals. one between the housing and the hollow (pto) shaft and one between the hollow shaft and the main shaft.
david
blake simpson
01-19-2005 10:09:00
 Re: 1979 2040 Oil Leak in reply to david val, 01-18-2005 02:00:23
when you say finish the work in the clutch area you do mean putting everything back together totally and then split it behind the shift lever, also how much am i looking at having to take apart for the seal replacement, am I going to have to take a bunch of gears apart or do the shafts simply slide out the rear with very little disassembly I have the tech manual but it doesn't address the seals specifically and I am kind of intimidated by taking the transmission totally apart but then again I don't want my clutch to get soaked with oil again. thanks for the help
blake
