I just can't resist such a "good" arguement with soooo many holes. I've used numerous tractors: John Deere: A, G, 730, 1010, 3010, 3020, 4020, 4230, 4440 IH: B, H, M, 460, 560, 756, 856, 1056 Oliver: super 77, 880, 1650, 1855 Ford: 4000 (4cyl), 9600 Moline: M670 Massy Harris: (model unknown...looked lot like fordson) Allis Chalmers: WD, WD45, D17, 180, 185, 200, 7040, 7060, 7045 Of all those tractors, the maintenance was kept up reasonably well. Of all of them, I'd rather trust my life to JD brakes then any other brand. Each of the various models and brands had good points and bad points. Some having more good then bad and vica versa. Of all of them, I felt JD placed controls and gauges in convenient and easy to use places more often then other brands. For instance, that 856 you are so fond of...I found the throttle to be in the most idiotic place, and shifting that transmission was extremely difficult compared to the 4020 with powershift. Course that's not a "fair" comparison. And no, JD didn't invent the powershift...they bought it from Ford and made it better. And I have driven the select-o-speed powershift on a ford (was the 4000)...JDs version is much much better. And for cold starting, that 856 again was probably the worst. 50 degrees F and you had to plug it in. The '68 4020 we had would start at 20 degrees F. My '64 4020 is cold blooded, but will start down to 40 degrees. I own a JD '52 A, '62 3010D, and '64 4020D. Would I consider buying any other brands...if the price is right and it fits what I want to use it for...yes. I like the AC WD45. A small Farmall might be ok such as a C or super C. An AC 200 diesel is a good 100+ hp tractor that runs cheap on fuel. Other than that, I just like the JDs too much. Course then you talk about the Steiger...but wait I thought your arguement was about IH vs. Deere????? But maybe that is fair, JD did buy a number of tractor companies many years ago....course the last time was how long ago? In fairness, JD did try to buy Ford before NH did and was prevented by Fed Gov't. or so the rumours were ...
