stuck valves on deere B
antique dave
01-16-2005 18:31:52
i have a 1943 or 44 john deere b both outside valves are stuck open. would like to know if there is any way to free then without disassemblying the engine. any help would be appreciated. thanks
Ben So Tex
01-17-2005 04:26:37
 Re: stuck valves on deere B in reply to antique dave, 01-16-2005 18:31:52
I have unstuck vavles with penatrating oil and tappy them and grabbing hold of the vavle stem and twist it slowly with a pair of channel lock pliers., did it on an A and a 60. Good luck Ben.
Clooney
01-16-2005 18:41:38
Dave, pull the valve cover, then spray penetrating oil on the valve stems & start tapping the valve tip with a small hammer.. You will probably have to pull the rocker shaft to allow good access to hit & move the valves.. If you can pull the spark plugs & bend a small copper line to point to the exhaust valve it would also help to try & spray some oil on the valves inside the cylinders..
Work slowly & be patient.. Most will eventually come free if you work at them.. Sometimes a little heat will also help but be careful you don�t overheat & ruin the valve springs (or pull them from the valve stems first)..
In a lot of cases when the valves are really stuck you have other stuck or rusted up parts also (like pistons)..
Clooney
