G gearshift lever
Daniel Chestnut
01-16-2005 16:54:58
Finally got to drive my G under its own power for the first time today, since the ground was froze. When I went to shift gears once, the gearshift lever came most of the way out. Can anyone tell me what is broken and what it will take to fix it? Thanks in advance.
Clooney
01-16-2005 17:28:06
 Re: G gearshift lever in reply to Daniel Chestnut, 01-16-2005 16:54:58
Daniel, probably the lower shift lever snap ring came loose (the one under the pivot ball) or is broken & allowed the shift lever ball to slide down the shift lever.. (kind of common of the old tractors)..
About all you can do is pull the trans shift cover off & take a look.. Pull the shifter cover & if you can�t find anything give me an E-Mail & I will send you picture on the shaft lever parts..
Clooney
