45 or 46 A mag
Larry Paz
01-16-2005 14:20:18
I have a chance to buy a 45 or 46 A. I will have to check the serial number to be certain of the year. The guy I am buying it from says it should run, but he says to get it running like it should it will probably need a new Mag and Carb.
Does anybody know if this takes a Fairbanks Morse Mag, or does it use the Wico, or does the manufacturer not make any difference?
Also, what is involved with changing out the mag on one of these? I would assume that somehow I would have to set up the timing again? Is that correct?
If I do have to time it, what is the proper procedure?
Thanks in advance for any advice you can give me.
Duane Larson
01-16-2005 16:20:10
 Re: 45 or 46 A mag in reply to Larry Paz, 01-16-2005 14:20:18
Larry,
The styled A's with pan seats came with a Wico C1042 magneto. If there is one there it is probably cheaper to rebuild than buy one. Fairbanks Morse also make replacement magnetos that will fit - FMJ2B6 or FMX2B6 with a short drive cup will work fine.
The easy way to do the timing is to notice that the drive cup has a male slot and it fits in a female slot in the governor case. Just bolt it up, and if it doesn't start but rather backfires, remove it and rotate the drive cup 1/2 turn and reinstall. There are other more formal ways, but that will work. If you get an owners manual for the tractor it will have timing information plus a whole lot more information. Call 1-800-522-7448.
Pappy
01-16-2005 15:52:37
We have a '46 "A" and It has a Wico "C" Magneto. I believe it is original. John T. has all the details covered.
John T
01-16-2005 15:46:31
Larry, I cant tell what Mag it originally came with, but the Brand makes no difference as long as its the correct coupler so it mates up with/into the governors female drive cog when mounted up. If you go with a Wico X Mag, they are fairly easy to buy n repair n get parts for versus some of the Fairbanks or others, its what I would use if it were me (or repair the one in it) as they are readily available n reasonable priced to buy or repair.
The timing isnt hard either, the initial static start timing is adjusted by having the mag mounted but loose (once inserted into governor) and start timing/adjusting it by rotating it CCW backwards to advance or CW forward to retard. Set the start timing so the mag snaps over just as the Left Cylinder is at its TDC which is when the Left Hand Impulse on the Flywheel is in the 3 o clock position lined up with a flat maRK ON TRACTORS SIDE if the covers off n you can observe it. Regardless, she needs to first snap just as the left piston crosses its TDC and then again when the right one does which is 180 of Flywheel/Crank revolution later. SHES GOTTA SNAP WHEN THE PISTONS AT TDC, which a simple CW or CCW rotation will adjust. If she fires too soon before TDC she may kick the flywheel backwards and can be hard on elecric starter drives, if too late she may not start as well.
The run time advance timing is when she fires at RPM (approx over 250) which is when the mags wind n trip spring assembly stops working and it fires n runs at straight crank RPM. Thats set on the rear on the Wico C and X Mags by loosening the 4 screws and setting the index mark on top to approx. 2 1/2 marks to the LEFT of straight up which is 25 degrees of run time advance over start time (depending on coupler). Set that first then install n set the static start time so she fires/snaps at the pistons TDC and youre close.
The the only issue remaining, is to have the Mag in correct n not 180 out, or you would have to reverse the top n bottom plug wires which would allow her to run anyway if it were a non reduction direct drive gear mag like the Wico C or X. However, if its a reduction drive gear mag like the Wico AP and some Fairbanks, they have to be in correct cuz a wire reversal will not make them run. The original configuration was top wire to left piston n bottom to right. However if a Wico C or X mag they may be reversed cuz the mag got put in 180 out as they fit either way into the Governor. If in reversed (180 out), they may pop n bang n spit n backfire or kick the flywheel backwards etc., which either a wire reversal ORRRRR RRR remove the mag and rotate its coupler or the flywheel 180 n stick em back in will cure. The reset the start timing as above.
Thers more but I wanna watch the Colts a lil bit, I will check back later so post any questions.
Good Luck n God Bless
John T in Indiana
