12 volt generator?
mattd
01-16-2005 14:09:24
i was looking at the serial tag on the generator of my '50 B and it said Delco Remy 12 Volt. Does this mean its for a 12 volt setup or what. Right now i have a 6 volt battery in it posotive ground. this may explain my charging probelms. does this sound right or what. it has a Wico mag, i dont know what model. any help would be appreciated.
matt
mattd
01-16-2005 17:57:39
 Re: 12 volt generator? in reply to mattd, 01-16-2005 14:09:24
the number on the tag reads 1101777 9K20. KK12 is stamped on the side of it. when i restored the tractor i had it rebuilt and bought all new wiring. i dont remember if they put a 6 volt regulator on it or not. it has 2 wires that comes out of it, black and white. and 2 other black wires that go to bolts on the generator. one of the bolts has F stamped by it, the other has A stamped near it. when i bought the tractor the generator had a smaller pulley on it as if the owner was trying to get it to have more output. as for the mag the serial tag is beaten up and i cant read any of it. i dont know if it clicks or not, ive never heard it when the starter is turning it over. it turns over ok. it starts it but i wouldnt trust it on a cold day. thanks for the help
matt
John T
01-16-2005 18:54:28
 Re: 12 volt generator? in reply to mattd, 01-16-2005 17:57:39
Thanks for the new info Matt, First of all, that 12 volt Generator on a 6 volt battery shouldnt have needed any smaller pulley or enhancements to get it to charge sufficient.
1) Okay the wiring, that A stamped on the Generator should be wired to the ARM terminal on the Voltage Regulator. That F on the Generator wires to the FLD terminal on the Voltage Regulator. The BAT terminal on the VR should wire up to the ammeter. SEE MY FIRST POST FOR MORE WIRIGN INFO AND CHECK IT OUT
2) Take a voltmeter or a test lamp and make sure the BAT terminal on the VR is always hot battery voltage???? It has to be or else the VR isnt gettign to the battery to charge it,the path is to n throught the ammeter then to the battery usually via the starter post.
3) The problem is we still dont know if that VR is a 6 or 12 volt, cuz IT NEEDS TO BE A 6 OR ELSE YOURE GONNA OVERCHARGE THAT BATTERY.
4) Okay, since you claim the Gen was rebuilt, lets run those VR by pass checkas n see if it charges then cuz regardless if the VR is a 6 or 12 volt, lets see if the Gens working.
5) Make sure the BAT terminal on the VR is wired to the ammeter and that it and BOTH ammeter terminals read hot battery voltage and BOTH the Gen and VR are well grounded and the belts good n tight and shes wired per this post and my earlier post. Then POLARIZE the gen per my post below.
6) Start her up n if she dont charge, dead ground the Gens F post to the case n see if she charges then??? If so but not before, the VR is bad or the wires open bwteen VR and Gen or the VR's not well grounded.
7) If still no charge, jump the VR;s BAT and ARM termuinal together n see if she charges then. if so but not before, the VR is bad.
8)If shes wired right and all is grounded and she dont charge despite the VR by pass tests above, I doubt the Gen is charging.
9 ) As a seperate Gen test, if the Gen will motor its usually good. Remove the belt and jump a hot wire direct to its ARM terminal n it ought to spin. The ground the Field n it ought to slow down a bit. Usually if it does both those its good.
NOWWWWW WWWWW WWWW if that Ignition never snpas at slow crank speeds but she still fires the plugs, it may be a Wico XB Battery Powered distributor instead of a mag. Are the plugs sparking ????? ? IS THERE A SWITCHED WIRE TO THE iGNITION THATS hot WITH BATTERY VOLTAGE WHEN YOU TURN AN IGNITION SWITCH on??? Does it have an Ignition switch or any wires to that Ignition???? If theres no wires to it but it stall spark, its a Magneto.
DO SOME OF THESE TESTS and let us know and post nback any more questions.
John T
mattd
01-16-2005 19:12:53
 Re: 12 volt generator? in reply to John T, 01-16-2005 18:54:28
John, there is one wire going to the mag. there is 2 other bolts to hook wires on to but only one has a wire on it. it has a switch on the dash and i can shut it off by using the switch. thanks for the help, i'll try the other tests tommorow as soon as i get a gasket for the sediment bowl.
matt
John T
01-16-2005 19:56:27
 Re: 12 volt generator? in reply to mattd, 01-16-2005 19:12:53
Matt, were makin progress, but still a ways to go.
1) A wire to the Ignition device and a dash switch still dont tell me if its a Mag or a Battery Powered Distributor, cuz the Wico X Mag can utilize a dash mounted kill switch which kills the spark if the stud on the Wico gets connected to a wire that gets a ground when that dash switch is closed.
2) HOWEVER, that stuff about other bolts to hook wires to sounds like it may be a Wico XB Distributor with a Ballast Resistor???? (but not used on a 6 volt tractor) cuz the Wico X Magneto has but one wire to it if it has the external dash kill switch. Some just had a lil piece of springy steel with a wood button that you pushed to ground it out n kill the spark.
3) Heres for sure how to tell which it is.
a) If it will run n spark WITH NO WIRES TO IT i.e. remove all wires to it n see if she still sparks????? THEN ITS A MAGNETO Also in that case, it has to make a sharp loud SNAP if you manually crank the flywheel/engine over, each 180 if its a Wico C or X Mag.
b) If it will only run if voltage is wired to any of its posts, but theres no spark if not, its a battery powered Distributor.
If you have a test lamp or voltmeter, see if when you turn the dash switch to ON voltage is at the Ignition, if so its again, a battery powered distributor. If theres a wire to it with no voltage ever but it runs UNLESS THE WIRE OR STUD GETS CONNECTED TO GROUND, ITS A MAGNETO. CAUTION dont short out a hot feed wire.
If she sparking why worry about it now. If you remove the plugs but have their wires attached and their sides grounded n turn her on n crank her over, do both plugs spark????? Or even just use the plug wires and have them to within a 1/8 inch away from tractpr frame iron and turn the switch on n crank her over n see if a good blue spark jumps that gap on both wires???? If the wired do but the plugs dont get a fresh set of plugs n try it???
Once we figure out if shes sparking we may or may not even need to go further or worry about it. However, if its a Wico XB Battery Powered distributor runnnign at 6 volts there shouldnt be any need of any external ballast resistance, that was used when they used it on 12 volt systems.
Insure theres battery vopltage on the Voltage Regulators BAT terminal and on BOTH sides of the ammeter and the Gen n VR are wired right and grounded, then Polarize n see if she will charge and if not do those 2 VR by pass checks, see if the plugs fire n post back. The directions above ought to enable you to figure if its a Mag or a Distributor.
John T
Clooney
01-16-2005 18:24:46
Mattd, that 110177 Delco is a 12 volt generator but a fairly low output one.. Only 8-10 amps at 2000 RPM�s..
You might want to pull the regulator off & look it over closely to see if there are any markings on it.. If you can�t determine if it�s a 6 or 12 volt you really can�t use it without finding out it�s voltage operation range..
You can test the generator to see if it will work though,,,,,
To Do That,,,,, ,,,
Remove ALL wires going to the (A) & (F) post,,,
Remove the belt,,,,
Then, ground the (F) post to the generator frame,,,
Make sure the battery is installed, charged, & grounded,,,
Then, run battery power form the battery�s non grounded post to the generators (A) post,,,
The generator should start to run like a motor,,,,
Then disconnect the grounded (F) post,,,, the generator should then speed up,,,
If it does the above the generator is probably good to go,,,,,
Then all you need to do is figure out if the regulator is 6 or 12 volt & if you want to run the tractor at 6 or 12 volts..
If the generator doesn�t pass the motoring test you might pull the end cover & make sure the brushes aren�t stuck or that the internal wiring doesn�t smell burnt..
Any other help just post back..
Clooney
John T
01-16-2005 14:47:56
Matt, its possible to use that 12 volt Generator to charge a 6 volt battery (with a good 6 volt Voltage Regulator) it ought to have plenty of capacity. You asked what the setup is, sounds like its a 6 volt (since a 6 volt battery) but it may have had that 12 volt Gen added at some time ORRRRR RRRR it may have been changed from 12 to 6 but I doubt that. If the 6 volt Battery cranks the engine fairly well, sounds like it has a 6 volt starter n was a 6 volt Tractor. HOWEVER, A 6 volt battery WILL NOT crank a 12 volt starter worth a dernnnnn nnnnn . I know youre lookin for answers, but I have to ask some questions so I can better help you::
1) THE IMPORTANT THING since you have a 6 volt battery, is do you have a 6 Volt Voltage Regulator????? cuz if you have a working 12 volt Gen and a working 12 volt VR, you can overcgharge n outgas and boil acid over n ruin a 6 volt battery!!!!!
2) Do you have a 3 or 4 wire (labeled with terminals BAT ARM FLD etc) about 2 x 2 x 3 inches or so usually black mounted on the Generator Voltage Regulator????? Or a smaller 2 wire (BAT and GEN) Cutout Relay and a Light Switch Gen Field Control??? Regardless of original, Ive seen all sorts of mods over the years lol
3) If you really have a Wico Mag (like say a Model C or X) it produces its own energy and is not wired to the battery or generator. HOWEVER, if you have a Wico XB Battery Powered Distributor, they require the CORRECT battery or ballasted voltage or you can ruin the coil etc. What does the label on the mag say it is????? Does it mag a loud snap/click as the engine is turned over slowly starting???? (Thats what a Mag but not the Distributor would do)
NOW TO THE CHARGING PROBLEM
Again, if you have a full fledged 3 or 4 wire VR
and a good battery I wouldnt worry yet if the Gen is a 6 or 12 volt, provided the VR is 6 volt and suitable for that original Positive Ground.
To save myself a ton of time Im going to provide you with a short version (I have more detailed if needed) standard generic charging system troubleshooting guide which is based on you having a Generator (6 or 12 volt),,,,, ,,,,, ,,,,,a Full Fledged 3 or 4 wire 6 Volt Voltage Regulator,,,,, ,,,,, ,,,,,a positive grounded good battery which hasnt been ruined by overcharging and has electrolyte above all the plates. If you happen to NOT have a 3 or 4 wire Voltage Regulator but a smaller 2 wire Cutout Relay and a Light Switch Field control, post back and I will revise the troubleshooting.
BASIC WIRING: (Is she wired correct and is the Gen been Polarized lately, see below)
BAT on VR to load (NOT to battery) side of ammeter. The ammeters other supply terminal has but one wire and it receives battery voltage usually from the starter switch. BOTH sides of ammeter must always read HOT battery voltage.
FLD on VR to Gens Field post.
ARM (or GEN) on VR to Gens Armature post.
LOAD (if you have a 4 wire VR) up to the BAT input on the switch, its what feeds loads like lights and ignition etc. If you only have a 3 wire VR that doesnt have the 4th LOAD terminal, the load side of the ammeter feeds the switch and its loads, thats the same terminal connected to BAT on the VR.
BASIC TROUBLESHOOTING
A. Preliminary
1. Make sure BOTH the Gen and VR are well grounded, they need to be for charging.
2. Make sure the belt is good n tight and not slick or glazed.
3. POLARIZE by momentarily flash jumping a wire from the VR's BAT terminal over to its ARM (or GEN) terminal and you should get a small spark.
4. Make sure the BAT terminal on the VR always reads hot battery voltage, thats where n how the Gens output gets to and charges the Battery via the ammeter. IF ITS NOT READING HOT make sure the wire is there to the ammeters load side and that BOTH sides of the ammeter are always HOT.
5. The battery must be good and capable of accepting a charge. Be sure there's electrolyte above all the plates and that no cells have a gray or milky color. B. TO SEE IF ITS A GEN OR VR PROBLEM
6. Start the tractor and ground the Gens Field post to its case ground. If it charges then,,,,, ,, either the VR is the problem,,,,, , or the wires missing from the Gens Field post to FLD on the VR,,,,, ,,or the VR isnt well grounded.
7. If it still dont charge (leave the Field grounded) next temporarily connect the VR's BAT terminal over to its ARM terminal. If it charges then, the VR's cutout relay is likely bad.
8. If still no charge, you have essentially by passed the VR's function, so if all else above is good and youre wired correct and the battery is okay, the Gen is likely the problem.
Typical Generator problems are brushes worn down too low,,,,, ,, or the brush hold down springs and assemblys are stuck or corroded and NOT holding the brushes tight down against the commutator (Try air and WD 40 etc to insure they are free n push brushes down),,,,, ,,,or the armature is bad/shorted,,,,, ,,,,, ,or the commutator is bad,,,,, ,, etc. etc. etc.
SOOOOO OOOOO OOOOO OO let me know if you have a 6 volt Voltage Regulator,,,,, what Mag you have,,,How well she cranks the engine over,,,,,and check the wiring and POLARIZE the Generator then,,,,, ,,,,, ,,,,, ,,run the tests above n post back your findings n any questiosn n I will help further.
Good Luck n God Bless
John T Nordhoff in Indiana
Jim Burns
01-24-2005 18:49:59
 Re: 20 amp alternator in reply to John T, 01-16-2005 14:47:56
My alternator on my JD 790 Tractor gets really hot
even when the tractor is shut off..It isn't the alternator that is bad because I put a new one on..mabye I have a bad voltage regulator?? HELP!
Clooney
01-16-2005 14:31:31
Mattd, you ask,,
Quote: --"it said Delco Remy 12 Volt"
--Yes, that is a 12 volt generator.. Your tractor was originally 6 volts.. That 12 volt generator will still work if it has the correct 6 volt regulator on it assuming it is working..
You probably should trade for a 6 volt generator or change the tractor over to 12 volts (either way will work)..
If you give me the number from the generator�s tag I can tell you it�s output & if it is in fact a 6 or 12 volt generator..
Once you figure out what you want do with it we can talk you through a generator & regulator test..
If you want an original 6 volt generator you shouldn�t have a problem finding someone to trade with you as those 12 volt generators are in demand..
Clooney
