5420 lift problems
SAMRAY
01-16-2005 08:12:44
Guys, I have a JD 5420 and the lift has a problem. The lift arms will only raise when the control lever is all the way up. Then, I can hear the hydraulic system squeal as if there is an overload. If the control lever is moved any at all, the arms go all the way down. The draft control has no affect at all. Thanks for any comments. Samray
leon
01-17-2005 04:55:16
 Re: 5420 lift problems in reply to SAMRAY, 01-16-2005 08:12:44
Sory to say that I can't diagnose this for you except to say that the squeal sure could be the pressure relief valve and I'b bet something is screwed up with the rockshaft control valve or it's linkages. I'd suggest you ask this question at your JD dealer's service shop. If they can't answer, I'm sure they can find the answer through D-tech
