CFWelles, I believe your tractor came with a AF 2698R speed hour meter.. The AR 21661R your book lists is the Deere replacement meter.. That assumes your tractor has 1st gear in the upper L/H corner of the quadrant.. If it has 2nd in the upper left all bets are off.. Here�s what you are basically looking at.. Your tractor came with the (at least as far as I can tell) AF 2698R. The replacement for that AF 2698R is (was) the AR 21661R but again as far as I know it isn�t available any more & it also looks slightly different than the original AF 2698R. About all that Deere has available (or had anyhow as I haven�t checked in a while) is the *AR 21664R �If you look in your book that * will be shown at the bottom of the page & says �for 8mph 5th gear assembly� Now on the looks.. They don�t all look the same.. But unless you want to have yours repaired & restored the AR 21664R is about all you have to work with.. Every now & then when I work with these speed hour meters I could tell the difference by just looking at the dash from the ground but if I haven�t looked at them for a while they all pretty well look the same. (there is a difference in the face speed charts, face numbering, etc.) I usually either repair the originals or use the AR 21664R.. If someone says anything about the speed hour meter or doesn�t like it,, all they have to do walk up and me & hand me the correct one & I will gladly install it to make them happy.. At the moment I have one tractor with the AR 21664R in it (that tractor also has the 8 mph 5th gear so the ground speed is close).. If you want a picture of that AR 21664R just give me an E-Mail & when I get a chance I will shoot a digital & E-Mail it to you.. I also have a box of speed hour meter parts with some of the old faces in it but if they aren�t marked I probably couldn�t tell what face goes with what part number.. Clooney
