420w air noise
rterry
01-16-2005 04:07:12
My 420 has started making a sound like it is sucking air, tractor runs and performs with no problem. noise is getting louder.
Clooney
01-16-2005 04:32:45
 Re: 420w air noise in reply to rterry, 01-16-2005 04:07:12
rterry, we're going to need a little more help from your end.. Take a piece of garden hose, piece of pipe, mechanics stethoscope with the diaphragm removed , or long cardboard tube, etc.. & listen at the carb area, intake manifold area, hydraulic pump & hydraulic lines area, & basically all around the engine area..
That noise could be coming from many things so we are going to need some help on at least where on the engine it is coming from.. Once we know the area we can help you identify the offending item that is causing the noise..
As a start make sure the carb intake hose clamps are tight & the intake rubber elbow isn�t cracked or pinched down.. Then make sure the air cleaner lower bowl isn�t full of water or ice..
When using that rubber hose- if the noise is coming from between the intake manifold & cylinder head & you define the exact area, put some heavy engine oil on that spot & see if the noise changes or goes away.. (that would mean you have a bad intake manifold gasket at that area)�
Clooney
