1010 PTO Shaft Seal
RANDAL
01-15-2005 21:10:09
I have a JD 1010 RUS. The pto shaft seal is pouring oil out. I have an I&T service manual but is not much help. It shows a 1010 with a single shaft with an external housing that bolts to back of transmission. Mine is molded solid and appears that I would have to remove the draft control assembly and the complete rear cover for the transmission. May even have to remove the rockshafts and its housing. Seems excessive for one seal. Tractor serial no. is 42500 trans. casting is t19169t and rear differentials are t17495t and t17494t. Any help is appreciated.
Loren NC
01-16-2005 06:46:12
 Re: 1010 PTO Shaft Seal in reply to RANDAL, 01-15-2005 21:10:09
I also have a 1010 and recently replaced a PTO seal on it. Mine only has one shaft but has two positions it can be installed for selection of shaft speed. Try this. Clean around the shaft REALLY well and see if you can't see the seal. Mine is external and just pressed in. I bought two from J-D so I could replace both of mine. Found out all I had to do was stick a screwdriver in it and pry it out. Put the new one back in slick as a whistle. Then I took the second one to an area bearings store and asked about a similar generic seal. Cost me $22 each from J-D and less than $8 for the same thing somewhere else. Guess who got one seal returned to them! My point is, if you clean the seal well enough, you can probably read the number on it and go buy yourself a new one inexpensively before you tear the old one out.
Bob
01-15-2005 22:04:50
Deere made a lot of changes to those tractors at serial # 42,001.
I'm not sure I understand what system you have... a single shaft like your book shows, but the newer version?
If you'd like a couple of parts drawings, post your email!
Randal
01-16-2005 07:47:44
 Re: 1010 PTO Shaft Seal in reply to Bob, 01-15-2005 22:04:50
Thanks for the follow up Loren and Bob. I will take a picture of mine so I can e-mail it this evening. The seal has a rubber coating on the outside where it sets against a solid ring pressed in from the inside of housing. I first thought it was a snap ring but it is not. I assume the rubber coating helps it seal when pressed against this ring. Cannot read any numbers because of the coating. The manaul shows that 1010 seals can be changed from the rear of housing mine appears that will have to be changed more like a 2010 from internal. I agree there where some changes between serial no.s but the I&T manual does not elaborate on this. Thanks in advance, Randal
