Gentlemen, Question number 2 for tonight. I chained the oil in my model 60 today. I've only owned this tractor for a couple of weeks. Looks like it has been quite some time since the oil was changed. It was extremely dirty and had a tremendous amount of grit/particle type material that I believe to be carbon deposits. These are fine pieces of material that could be crushed if you rubbed them together in your fingers. I cut the oil filter apart and it was loaded with them. The amount of junk in this engine oil was/is a bit disturbing. I read in the manual about "flushing" the engine with kerosene, but frankly I was afraid to start the engine up for fear I'd move all that junk through the engine. When I reached up through the drain plug I could feel a tremendous amount of sludge, almost 3/16 inch thick. I elected to put 1 gal of kerosene in the sump then rock the tractor back and forth to adjatate it. I did this five times (I ran out of kerosene). The fuel went in clean and came out FILTHY DIRTY and loaded with these pieces of material. I found no metal pieces or chunks though. I filled the engine with 10w30 Pennzoil and a new JD filter. I thought I'd run this for a few hours or so then change it again. Does anyone want to venture an opinion about this problem? Also when you run the engine with just the kerosene in it, do you put an oil filter in? If so I'm assuming you disgard it and place another one then? I'm a little confused was JD wants there. Do they want you to run the old filter with the kero? What about using a motor flush like Gunk's 5 min flush? Any help is appreciated. Tom
