Suggestions Welcome!
Tim A.
01-15-2005 18:41:45
I have soon to be 4 year old twins...a boy and a girl. My son is a tractor fanatic. Over the next couple of years I would like to find an older JD with WFE than we can tinker on and enjoy together...something that he can then use for raking hay or pulling hay wagons etc...I would be looking for something that parts availability is reasonable and not such a collector item that prices of everything would be exceptionally high. A farmer friend of mine suggested something with a foot clutch vs a hand clutch...but I am not sure. What tractor or tractors would you suggest I be looking for...I do realize I have quite a while yet...but you never know when you will run across the right thing.
Thanks for your help.
Tim
Pappy
01-16-2005 16:11:00
 Re: Suggestions Welcome! in reply to Tim A., 01-15-2005 18:41:45
What would be wrong with an "M" John Deere. They are small and should fit the bill.
Mike M
01-16-2005 18:52:37
 Re: Suggestions Welcome! in reply to Pappy, 01-16-2005 16:11:00
Nothing ,except that the pedals will be hard to reach unless you put blocks on them.
Pappy
01-16-2005 16:11:13
Tom in PA
01-16-2005 15:10:06
 I have little munchkins too in reply to Tim A., 01-15-2005 18:41:45
Tim,
I have 3 kids myself, two boys 6 and 4 and a daughter who is 2. I recently purchased a JD 60 that has a loader on it. The 6 yr old can run the hand clutch with my assistance. He is mechanically inclined and understands the hand clutch well . He can stand and steer the tractor with help from me. I imagine he could steer without me if the power steering was fixed (or if I took the loader off). We use 2nd gear and partial throttle.
The 4 yr old can't steer the tractor at all without assistance. He does like to sit on my lap while I drive. He cannot reach the hand clutch without standing up and leaning around the steering wheel. I'm not comfortable with him doing that. So he get "rides" while his brother gets to "drive."
Both like to sit and play on the tractor in the garage. Neither weighs enough, or is strong enough, to start the engine using the foot starter (which I consider a HUGE PLUS). Both bounce on the seat and move the gear shift around. They don't understand why it won't shift into "every" gear when it isn't running. I tell them the tractor doesn't feel like going into that gear, and they put it in another. Both like to play with the hydraulics and make silly tractor sounds. As a result I have lots of spit on the tractor (they're making the PUTT PUTT PUTT sound). Both think it is cool to put stuff in the bucket loader and actually helped me load up a bunch of big rocks the other day. Kinda odd to see a Tonka truck dumping rocks into a JD 45 loader. We're making memories.
Hope this helps. I like my 60. Feel free to email me direct if you'd like. [email protected]
Tom
Dave NE IOWA
01-16-2005 14:05:19
Would you consider a AC G ? I live in town and have green broke quite a few very young kids. A very slow creaper gear, Very easy to steer. Another option is the clutch and brake are like the Ford 8n"s except it takes very little weight to enguage either. I always told them if they get in trouble just stand up! You have to stand on the clutch and brake. I will probably open up a can of worms with this wide front end comment but as far as I can see a narrow front is more stable than a wide front. Take a toy tractor with a wide front on your kitchen table on books etc to imitate a hillside, now tip the tractor over sideways to the point the front wheels actually help stabalize the tractor--you are dead meat probably before that point. Some tractors are no doubt better, but the G AC has a pivot piont that you can wedge a very short 2 x 4 block under it to force both front wheels on the ground. They used to haul the G"s on rail cars and trucks with one front wheel hanging over the edge to make more room, That block will never fall out despite what the DOT may think! With the G you can walk behind it and shut the engine off, When dealing with very very small kids 3-4 year olds that want to imitate their very old 8 year old sibiling - I tie a twine string on to the coil wire and around my wrist-- just in case I would fall down. Dave NE IOWA
Mike M
01-16-2005 11:14:04
I grew up driving a JD B and a JD 70 you can drive these standing up while an adult sits in the seat to keep you in line,they also have very good brakes. Just because a tractor is small doesn't make it safer or easier to operate in fact I think the opposite may be more true. The largest tractors have hyd. power everything very easy to operate,seat belts and a ROPS.Take him to a very large farm and climb up in the cab of one of those huge 4 wheel drive giants out in the middle of a very large feild and you both will have a blast about as safe as it gets.
John Van Valkenburgh
01-16-2005 07:50:48
I would suggest a later model B or a 50. I think the tricycle is easier to steer and if for no other reason be as good a bet as a WFE.
There is a 12 year old girl who boards a horse on the farm where I live, and I've taught her to drive my 50 and use the brakes to turn tight corners when dragging a tine harrow in the riding ring. I am of course careful to always stay nearby when she runs the tractor and I keep it in 3rd gear which is quite slow. This girl is tall enough to comfortably use the brakes and strong enough to steer and use the hand clutch. She knows how to shut off the engine as well as start it. I've also found that she is very bright and will listen carefully to what I tell her. I think under these strictly controlled conditions that she is quite safe.
As far as working on the tractor goes, things tend to be pretty big and heavy for a child, but if they are inspired... well that can make up for a lot.
I think old tractors are a wonderful way to share time as well as build confidence and positive experiences for a child. I've often pointed out to this girl that the size of the machine is not the important thing as much as knowing how to use it and paying attention to what you are doing. I've often stressed to her that possibilities for what she can do are very broad if she approaches them with determination and takes the time to learn.
Best of luck!
John
1953 Model 50
Loren NC
01-16-2005 06:59:18
 Interesting suggestions! in reply to Tim A., 01-15-2005 18:41:45
I find the comments that you should start with an 8N to be interesting. That was the first tractor I drove and I have disliked them ever since. The pedals go straight down and the only amount of pressure you can put on them is equal to your weight. I must have been at least 50 pounds when I first drove at 8 y/o and there was NO WAY I could make that tractor stop. I started my own son on a narrow front Allis WD with a hand clutch. He could slide off the seat and press the brakes while he worked the hand clutch. Great combination, in my opinion. If you get an older tractor without power steering, a narrow front would be easier for a kid to handle. However, I do agree with those who say stability IS an issue with narrow fronts if you are working hilly terrain. I now have a wide front J-D 1010 and it is much more stable than the narrow front tractors I grew up with.
Kent W
01-16-2005 05:13:23
Tim, I have a GP and BR that my 6 and 9 year old can drive. For me the enclosed operators� compartment (fenders) gives my wife a level of comfort and I can walk next to the tractors and grab the clutch if needed. The initial cost of these tractors is a little higher but then the resale will be higher also.
Marty Z
01-15-2005 21:46:56
I'm a JD guy too but I would start a little guy out on a farmall cub or a Ford 8N . Both are cheap and easy to run.
I have 5 JD's but I still love my 8-N and they have come to be cheaper since every one is buying the 4wd stuff for those 5 acre lots.
Marty Z
JD Jerry
01-15-2005 21:08:38
I started my grandson on my B when he was three. Loosened the clutch up so he could handle it and he gave his Dad a ride when they came to pick him up. He was using the clutch for brakes but the yard is flat so it wasnt to hard on it. Now he is 10 and drives my 4020 powershift a little. He runs the loader too. Come to think of it he has driven the 7520 too.
billde
01-15-2005 20:53:06
John Deere made several small wf tractors that have foot clutch. Model M, 40, 420,and 430. One very important thing to remenber, if they can't reach the foot clutch, they can't operate the brakes so a hand clutch is no better. When I and several of the kids in my neighborhood started driving tractors our dads screwed blocks of wood to the pedals. That may not have been the politically correct thing to do, but it sure got us in the field at a young age! And just an opinion, but, I strongly disagree that a wide front is not more stable than a narrow. If that were not true, why are we not driving 3 wheelers instead of 4 wheelers?
jdat jared
01-15-2005 20:50:59
i would suggest a JD model 60, i have my grand fathers and it is a nice tractor, it comes you can find most of the standard items of todays tractors on the 50,60,70 (like PS Live hyd. and PTO). i have been able to find almost all of the parts that i need either from deere, or from ads in the local paper. the 60 is a common tractor, at auctions they usually go fairly cheap.
CLW
01-15-2005 20:13:28
47-52B would be cheap and a good tractor. Wide front may be hard to find. Do you need WF for any good reason? I started on one at a very early age.
CLW
Tim A.
01-15-2005 20:18:49
 Re: Suggestions Welcome! in reply to CLW, 01-15-2005 20:13:28
I wanted WF for stability...it would be safer...but no other reason.
Tim
CMB
01-15-2005 20:32:22
 Re: Suggestions Welcome! in reply to Tim A., 01-15-2005 20:18:49
In actuality, a wide front adds nothing to stability. If it's going to turn over, the wide front won't prevent this from happening. Personally, I'd start that small of a child with a hand clutch, as he most likley won't have long enough legs to operate a foot clutch safely. My suggestion-get a late "B".
CLW
01-15-2005 21:00:42
 Re: Suggestions Welcome! in reply to CMB , 01-15-2005 20:32:22
I agree with CMB. A lot of people think the wide front is harder to turn over. Not the case. Someone posted a while back that they watched a film by a safety group and they put a M Farmall with and without a wide front across an increasing slope. They went over at the same spot. With the hand clutch you can back it off enough that a young person can pull it back and yet not so much that it slips.
CLW
jhill
01-15-2005 19:42:02
I also learned to drive on an 8n and it would be a good choice but if you want a Deere I would suggest a 520. They are fairly modern can be had with WFE power steering, live hydraulics, live PTO and 3 pt. Best of all they are still priced reasonably.
Jerry
720diesel
01-15-2005 19:23:02
I am 15 and cut my teeth on my dads 720 diesel that is now mine.Hand clutch will be much easier for short legs that arent that strong yet.Try a 720 diesel. I would be great to pull wagons and rake hay and farm with.
mattd
01-15-2005 19:16:31
i hate to say this but i would suggest a ford 8n, naa or somthing of that size. the first tractor i learned how to drive was a naa. they have wfe, foot clutch, 4 gears, and 30-35 hp. now i have the same naa and use it for mowing hay, raking hay, pulling pipe trailer. there is a lot of them around and dont cost much and there is plenty of parts available. although there are a lot of good jd tractors that would be perfect.
matt
