I thought that I remember a removable cover on one side of the bellhousing about 9 cm in diameter. The removable cover is actually there so that you can grease the throw out bearing, but I believe that you can visualize the hydraulic pump's coupler through it. Unfortunately my tractor is across town so I cannot just go outside and confirm all of this. I wanted to ask one more time: Your hydraulics worked fine for those two miles, then suddenly and unexpectedly quit, right? As it stands now, your tractor will steer, but without power assist. Is this correct? If there was a SUDDEN demise of the hydraulic system, the clogged filter theory seems less likely, but would be easy to check. When you installed the filter, were you sure that you properly installed that extra rubber gasket at its distal end, as it shows in the manual? The violent shaking back and forth that you described made me think of the lines being reversed, because that's what my tractor did when I accidently hooked the lines up incorrectly. It also made me think of the valve at the base of the steering column, because it that valve is sticky and moves back and forth uncontrollably, that can produce a violent shaking of the steering wheel. Of course it would not explain the loss of hydraulics to the rockshaft as you pointed out. Try and measure your hydraulic pump's output pressure by rigging up a pressure gauge onto the tractor's breakaway couplers (if it has one).
