G John Deere--Am I expecting too much?
Village Blacksm
01-15-2005 16:13:38
My 1950 "G" JD does not pull like I think it should. I don"t know what to expect. It has been overhauled, runs like new, starts like new and sounds like new. It just won"t pull like I think it should. It has no ballast, but in second gear it will lug down and not spin a wheel. It will never mis-fire, but will lug down to 300 RPM (probably) and keep on barking. I feel that a "G", at full throttle, ought to at least spin the wheels, instead of just lugging down to very low RPM. I am somewhat comparing it with a 1952 "A" gas burner which is impressive in it"s pulling power. AM I EXPECTING TOO MUCH???
JD720
01-16-2005 13:46:19
 Re: G John Deere--Am I expecting too much? in reply to Village Blacksmith, 01-15-2005 16:13:38
Don`t forget the G is geared faster than the late A. First gear on a G is about the same as second on the A.
Village Blacksmith
01-16-2005 08:59:16
Thanks to all who responded. I do not use the "G" for pulling, just for playing around in the dirt. We were pulling a 10' tandem disc in loose soil the last usage. After reviewing all the suggestions, I am going to adjust the start timing and the run timing up to maximum advance. Hope this will pep it up. I can open the load needle up until it starts to puff a little black smoke and it really doesn't help. Thanks to all!!
It has a Wico X Mag.
BushogPapa
01-15-2005 18:09:06
If you still have the original pistons (4.9 to 1)
That is about what you will have..the power of a Gas "A". If you have increased the compression...you should certainly have more power than what you say.. Do check that the Entire intake system has been cleaned..Mud-daubers can buile nests in the upper air intake, and choke the air flow to an incredible degree... Soak the air-cleaner in solvent to be sure it is cleaned out... A "G" with some compression should be equal to a good 4-plow tractor... Why are you not using 1st gear..?? I have seen perfectly goos original early "G"'s that couldn't pull the sled 50 feet..others that had been set up to pull, would never pull down..!!
Clooney
01-15-2005 17:59:21
Village Blacksmith, that �G� has more weight than an �A� so will pull down a bit better before spinning a tire..
You didn�t say what you are pulling or what type of soil your rear wheels are locked into but that �G� should pull about what that �A� does under the same conditions..
As Garland said make sure your air cleaner upper inner filter mesh isn�t plugged with dirt (common on the old 2-cylinders).. Then try advancing the ign timing a little (mark the top of the mag to governor so you can put it back if needed then rotate the top rearward about 1/8� to 3/16� & see if that perks it up a little.. (the timing on those G�s was figured for running on tractor fuel so can be advance about 5� more on gasoline)
Make sure the carb is opening ALL the way while under load (this is a common problem also) & try opening the load needle a little more & try it.
Maybe make sure you are getting a good solid fuel flow to & through the carb (make sure the 3-way valve isn�t restricting the fuel flow (another common problem)..
If it runs good at light load & not up to par under a heavy pull ign timing might be the problem or lack a good air supply to the carb..
Clooney
Mike M
01-15-2005 17:29:40
Only way to get any idea of where your at is to run it on a dyno.
buickanddeere
01-16-2005 07:25:26
 Re: G John Deere--Am I expecting too much? in reply to Mike M, 01-15-2005 17:29:40
Amen on the dyno test and tuning while on the dyno. A G fresh out of overhaul set up for gasoline with pistons & cold intake should make an easy 45-50HP. The stock 70 gas on a tough clay power track with 15.5's will just spin the tires while carrying the front tires a little in the 6500lb class. I doubt it could handle 2nd unless on the loosest of sand tracks. There is even another HP or two extra in the cam. No use rebuilding the engine without ensuring the lobes an follows are trued up. When grinding cams, Roberts Carb can do a stock or improved version.
Garland(Gman)
01-15-2005 16:46:47
V.B.S. If your "G" still has the cast iron pistons and hot manifold(all fuel engine)it has a H.P. rating of 38 hp were as the "A" on gasoline and a cold manifoild is producing about the same H.P. as the "G". Check and make sure the air cleaner is clear and recheck the engine timing. Gman
mbptractor
01-15-2005 19:42:42
 Re: G John Deere--Am I expecting too much? in reply to Garland(Gman), 01-15-2005 16:46:47
I have a 47 j.d. bored .125 over with high compresion piston . the cam was reground for low end torqe. runniing 15.5 38. my tractor in the 6500# class in 2nd gear runs out of power also. But if i run 1st gear it will never run out of power it will spin out first. I pull 7500# class in 1st an usualy place in the top 3. and do ok in the 8500# class. SO i realy dont think you have a problem with your tractor. try 1st gear and i think you will be happy.
