Thermostatically Controlled Engine Coolant Heater
John in Md.
01-15-2005 13:02:15
Any one know of a source for parts for the John Deere engine coolant heater. The local dealer said they are no longer available thru Deere. Then he tried to sell me some red thing made in China.
When I plugged it in yesterday saw some sparks and it doesn't seem to heat up like it did(so I guess the thermostate is getting weak). I know how to jump the thermostate, but I would prefer to repair it. If you can give me any leads I would appreciate it, or if you have a used one let me know and I'll get back to you. Thanks.
Bob
01-15-2005 21:50:38
 Re: Thermostatically Controlled Engine Coolant Hea in reply to John in Md., 01-15-2005 13:02:15
What's this on? Are you talking about the external Deere tank heater with the element held in with 4 bolts?
John in Md.
01-16-2005 02:26:25
 Re: Thermostatically Controlled Engine Coolant Hea in reply to Bob, 01-15-2005 21:50:38
It's a can heater on a 730. Has a heater hose in the bottom for cold in, and a hose back to the head for the hot return. It's aluminum with a JD on it. Hope that clears it up.
donmyeil
01-16-2005 06:09:36
 Re: Thermostatically Controlled Engine Coolant Hea in reply to John in Md., 01-16-2005 02:26:25
Sounds like the John Deere tank heater like the 4020's used. I just put a new element in one the first of the year. They are still available.
John in Md.
01-16-2005 14:15:40
 Re: Thermostatically Controlled Engine Coolant Hea in reply to donmyeil, 01-16-2005 06:09:36
Did you get it from a John Deere dealer? If you did , did he have it in stock or did he order it, and from where? Our local parts guy said NLA.
Bob
01-16-2005 18:24:50
 Re: Thermostatically Controlled Engine Coolant Hea in reply to John in Md., 01-16-2005 14:15:40
For the aluminum external tank heater with the element/thermostat/cord unit held in by 4 bolts, the element part number is AR42883. My Deere dealer shows 4 in stock at $53.00 each. Does that sound like what you're looking for?
