JD 320S gauge questions;
cdm
01-15-2005 12:21:11
I just bought 320 s, and am ordering manuals. in meantime, can someone help me with following
1- there are 2 holes in dash for gauges, which gauges went in those holes? I can't locate normal connection for water temp gauge?
2-There is 3-3/8 inch diameter hole for a tach. where would the tach cable connect?
Thank in advance
Clooney
01-15-2005 12:33:20
 Re: JD 320S gauge questions; in reply to cdm, 01-15-2005 12:21:11
CDM, you ask,,
Quote:--� 1- there are 2 holes in dash for gauges, which gauges went in those holes? I can't locate normal connection for water temp gauge?�
--A water temperature gauge & ammeter went in those holes.... The temperature gauge was mechanical so wouldn�t have a connection at the dash.
Quote:--� 2-There is 3-3/8 inch diameter hole for a tach. where would the tach cable connect?
--The large center hole was for an electric hour-meter, no tac cable to that..
Clooney
