B push rod tubes
Canetractor
01-15-2005 11:31:38
I read the archives relating to push rod tubes but my problem is the dealer here says they are no longer available! Has anyone discovered a manufactured tubing that will work? Thanks!
Canetractor
01-15-2005 19:47:54
 Re: B push rod tubes in reply to Canetractor, 01-15-2005 11:31:38
Thanks for all the info Guys. Looks like I was misinformed about the availability.
Earl S.
01-15-2005 12:55:55
Here in Illinois we have a lot of lime scale that builds up around the tubes .After you get the old tubes out just take your torch and heat the lime scale and it will pop loose ,blow out.I have some new "B" tubes #B1800P The big end is .7325 the small end is .725. Be carefull when you drive out the tube you don't put a scratch in the head.Take some 400 grit paper and clean the holes in the head. I have a bushing driver turned down "OD". smaller than the tube.I usually use teflon thread sealer on the tubes.Earl In Illinois
BMAN
01-15-2005 11:50:50
They are available from John Deere. The part numbers have changed. For the Unstyled B use B1290R-$9.50 ea. For the Styled B use B1800R-$17.75 ea.
John T
01-15-2005 11:39:02
Its been a couple years since I bought my last at Mother Deere. But as I recall the one end is swedged a slight larger OD about the first 1/2 inch or so, and it drives/presses in that larger (head sidend obviously last, so regular straight tubes witn work unless you duplicate that one larger end. You have the old ones for pattern/dimensions?? Mine went in real easy when I had them froze a while before installation, cleaned n dried em and they went in and NEVER LEAKED !!!! If I recall, my new ones were brass versus steel??
Good Luck, John T
ebbsspeed
01-15-2005 14:51:45
 Re: B push rod tubes in reply to John T, 01-15-2005 11:39:02
Mine were brass, too. Got them at the dealer in Lees Summit, MO.
