620 hour meter question
Larry L. Goodw
01-15-2005 11:24:25
I recently fixed several problems on my 620 so I could use it. The tach cable was missing so ordered a new one, WOW!! Anyway, installed in tach but doesn't seem to want to turn inside tach and don't want to force anything. I will take it apart for a look. My question is are the replacement tach's from Deere original looking? If not, what do I do? It still looks pretty good and the needle is attached. It has a bout 4900 hrs. on it but don't know when the cable was removed. What are your thoughts? Thanks
Emerald70D
01-15-2005 12:38:25
 Re: 620 hour meter question in reply to Larry L. Goodwin, 01-15-2005 11:24:25
Larry...I was just trying to find out what the correct part number is for a 620 tachometer. Is the one on your's AA6572R?? I have a spare but can't remember which JD it fits. Thanks!
Larry L. Goodwin
01-15-2005 13:19:26
 Re: 620 hour meter question in reply to Emerald70D, 01-15-2005 12:38:25
Emerald70D, I see from Clooney,s response that you have an original 620 tach. I would be interested in it if you decide to sell! I think you can send me an email directly. If not, post back and I will have to un-hide my address. I think it should work this way.
Emerald70D
01-15-2005 14:01:41
 Re: 620 hour meter question in reply to Larry L. Goodwin, 01-15-2005 13:19:26
Larry....if you will send me an e-mail note, I will reply to your address and attach a picture of the 620 tach I have. You can e-mail to [email protected] Thanks!
Larry L. Goodwin
01-15-2005 13:08:16
Emerald70D, The original tach that is in the 620 is AR 21662 R. I stopped at the local Deere store this AM. They list the part now as AR 21664 and want $155. for it. Don't know if it looks the same or not. I will look up your part no. and see what it fits.
Clooney
01-15-2005 13:17:43
 Re: 620 hour meter question in reply to Larry L. Goodwin, 01-15-2005 13:08:16
Larry, the AR 21664 is the speed hour meter from a 720 with 8mph 5th gear.. It will fit your tractor but the ground speeds will be way off & the face will be quite different than your original (it sounds like your tractor already has the replacement AR 21662R in it)..
Clooney
Clooney
01-15-2005 13:26:17
 Re: 620 hour meter question in reply to Clooney , 01-15-2005 13:17:43
Larry, if you can't work out a deal with Emerald70D give me an E-Mail as I have an AR 21664 in my 720D with 8 mph 5th.. I can take a picture of the IP area & then you can decide if it is close enough to look good in your 620 before buying from Deere...
Clooney
Clooney
01-15-2005 12:46:00
Emerald70D, the original �American� (MPH not KPH) 620 tac should be the AA 6572R,,, the replacement should be (unless even the number is subbed) AR 21662R..
Clooney
01-15-2005 11:51:17
Larry, your TAC is probably frozen up inside.. You might be able to pull the TAC out & work some oil in around the cable drive spool (place a 1� high rubber hose on it that fits over the drive furled threads then add some oil to the hose) .. Then use a tool to try to turn the TAC input & see if it will free up.. I have taken those TAC�s apart by peeling the trim ring edge up in the rear, then removing the ring & screws & pulling the guts out.. To put it back together place a paper or cardboard on a solid flat surface & set the trim ring on that with the TAC & glass in it then use a wooden dowel & hammer to re-set the ring�s edge back down flat over the edge of the TAC housing..
As far as a replacement TAC looking original.. Assuming there is even one still available it would probably have a more universal face & probably not have a matching road speed chart but unless held up next to the original probably wouldn�t look too different at a glance..
Clooney
