G oil pressure
Daniel Chestnut
01-14-2005 18:22:23
I finally got my G running over Christmas break. I put on an oil gauge that goes up to 60psi that I know is good. When I started the G, it would show 30psi. I was able to buy a John Deere oil pressure gauge that has the markings low, medium, and high. Then I put this gauge on it. Now it shows high oil pressure when idling, revved up, cold, or warm. Should I try to adjust the oil pressure to where it shows medium or should I not adjust it and run it? Thanks in advance.
Clooney
01-14-2005 18:45:46
 Re: G oil pressure in reply to Daniel Chestnut, 01-14-2005 18:22:23
Daniel, the correct oil pressure is 10-15 psi at fast idle HOT� That isn�t just idle it for a while hot but working hot.. My guess is your oil pressure will come down after you put it to work for a while.. On those old Deere�s with those big cold steel oil sumps it takes a long time to warm that oil up..
If it�s still high after a good work out then set it down a little..
Clooney
