brakes on H
jr55
01-14-2005 13:05:34
Do the shaft that the pedal is on come out of the housing and the adjusting screw? If so, How
Pat Browning
01-25-2005 15:26:10
 Re: brakes on H in reply to jr55, 01-14-2005 13:05:34
Hello jr55;
You should consider acquiring manuals for your tractor. Shoot me an e-mail and I will help you source them. (PatB)
[email protected]
Mark Scholten
01-14-2005 17:17:52
If by some chance you destroy the axle housing, I have a left and a right bare housing. Mark
Gr8Bald1
01-14-2005 14:41:12
I recently took apart a frozen brake from my B. That pedal shaft was pretty screwed up by the time I got it out. I asked the parts guy at the local Deere joint if those shafts were still available and how much they cost, he said "Yes, they're two and a quarter." I said "Two dollars and twenty-five cents?" He said "No...." So the moral of the story is heed Clooney's advice and be as careful as possible with those parts. My story has a happy ending--I got a pedal shaft for my B free from a salvage guy.
Clooney
01-14-2005 13:39:26
third party image
jr55, yes they both come out, BUT!!!,, you have to remove the axle housings & pull those pesky brake drums from the axles then both go to the inside to come out.. The brake pedal shaft will come out after removing the brake pedal on the outside.. & the adjuster will screw into the inside & come out (but it�s probably rusted tight & will need heat & penetrating oil to move).. Those adjusters do break off easily so use lots of heat & lots of caution..
Clooney
