Corn Head Grease
TomL
01-14-2005 12:10:11
Does anyone know where to purchase corn head grease other than JD dealers or where to order via internet. I have check with all dealers within 50 miles and none of them stock it or want me to order 30 cartridges. I don't need that much, only one or two to use for lubing steering gearboxes.
rick in sc
01-15-2005 11:17:52
 Re: Corn Head Grease in reply to TomL, 01-14-2005 12:10:11
TomL,Missed your post the other night, I live near Donalds in Abbeville Co.
billyiron
01-14-2005 21:35:14
Agco dealers have the same stuff---billy
Henry J
01-14-2005 15:26:42
Tom
I have heard that an equivalent grease can be purchased but have not had to look for it. I just came from looking over a tube of that stuff and the only thing I could find that might be a grease spec was NLGI Grade No 0
You might try a couple of places on the phone if you want it out of a tube - don't know for sure though.
Good luck
billde
01-14-2005 13:43:57
I have used STP as a temporary solution, real thick, and tends to cling to gears well.
Mike Aylward
01-14-2005 12:19:42
Tom, are you in an area that does not raise corn? I can't imagine a John Deere dealer that wouldn't carry this grease. However, if yours doesn't, a web search of any dealer in the midwest should bring up more than you will know what to do with. Any good parts man should be able to ship you as many cartridges as you want. Hope this helps. Mike
TomL
01-14-2005 12:41:48
 Re: Corn Head Grease in reply to Mike Aylward, 01-14-2005 12:19:42
Thanks Mike,
The problem is the JD dealer within 50 miles of me are not Ag dealers, they are lawn and garden or compact tractor dealers. I have emailed two ag dealers about 50 miles away with no response.
Tom
Clooney
01-14-2005 12:17:18
Tom, I make my own (well sort of) .. I just mix a tube or two of moly chassis grease with 140 weight gear oil until it will just pour like thick honey on a cold day.. That really works good as the gear oil will separate a little work it�s way into the bearings where grease won�t go & if a little gear oil migrates out it still leaves the chassis grease.. I have been using this for years with real good success (much better than plain grease & stays in better than gear oil) ..
Clooney
TomL
01-14-2005 12:45:49
 Re: Corn Head Grease in reply to Clooney, 01-14-2005 12:17:18
Thanks Clooney,
I do have a tube of JD HD Moly that I could mix with 140W, now to get some 140W. All I have now is 90W GL1.
Tom
Clooney
01-14-2005 13:02:14
 Re: Corn Head Grease in reply to TomL, 01-14-2005 12:45:49
Tom, you can use the 90 weight to mix with the grease all that will happen is the small amount of gear oil that separates will tend to run out easier.. It will still leave the grease where it belongs & work fine it will just tend to make a slight mess under the tractor�s front end on the first couple of warm days.. It will just wipe right up & after a little seepage you won�t even know. I have used 90 weight & it probably will leave a couple of small oil spots then dry up after a short while & quit seeping.
I like that much better than plain grease as the grease won�t flow into the end bearings by itself & grease will tend to get worked away from the worm & sector & once displaced won�t migrate back so that leaves the worm to sector dry after a while..
Corn head grease does work good but that can also seep a little out in warm weather & make a mess.. (much better than plain gear oil on an old Deere though) as those old steering gears aren�t worth a hoot at holding modern gear oil in..
Clooney
