Tug, Youre welcome, looks like you got some great steering advice above !!! It sounds like you have already cured what are fairly common causes of that erratic ammeter deflection, which are: Rough or Pitted or Dirty (grimed n oiled up or carbon coated) Generator Commutator segments,,,,, ,,,or the insulators between the commutator segments arent undercut properly,,,,, ,,,,,or the Generator brushes are chipped or worn low or not smooth,,,,, ,,,or the contact points in the Voltage Regulator are burned or carboned,,,,, ,,,,or theres a loose or shorted wiring or wirign connection(s),,,,, ,,or a loose or bad ground at the Gen or VR,,,,, ,,,or maybe even the belt isnt good or tight,,,,, ,,,,or even a faulty ammeter itself. If the Gen and VR are new/rebuilt as you say, you might take a look at all the Gen and VR and Ammeter and Ground Connections (remove, clean n wire brush n reattach),,,,, inspect n tighten the belt. To check for a faulty or carboned or burned VR contact(s) I would try dead grounding the Gens Field post to its frame n see if she smoothes out then?? If so, check the VR"s ground and all the connections, cuz if they are all good, it sounds like a VR field control relay contact problem. Likewise, by pass jump the VR"s BAT terminal over to its ARM (or GEN) terminal or direct to Gens ARM post, which by passes the cutout relay, n if she does better then, check all the wiring conenctions, but if they are good but the by pass smoothes her out, I suspect faulty cutout relay contact points. If she acts the same with BOTH the Gens Field grounded and the VR"s cutout relay by passed (jumped around) and all the wirign and grounds n belt are good,,,,, then I think its NOT a VR problem but suspect the Generator, like the commutator or brushes as noted above. Take care Tug Man, John T
