Tom I would first check the operation of the detent that buick referred to. If if does not click/drop in the detent in both the in and out position something is probably fishy with that mechanism, like the spring or the detent ball it pushes on. On the shaft, there is a slider called a coupler, I believe. When I had mine apart, I noticed that the edges were severely rounded off from grinding the thing into gear. I replaced the coupler at that time with a good used one, but we are talking a heck of a lot of work to get to that coupler. The reason mine was so aboused was that it was obvious that it was being crunched into gear as the two stage clutch was all out of adjustment and was not disengaging the pto. Also, my lever was bent, broke and welded back on in such a way that the thing was not allowing the shaft to rotate all the way into detent. Along with that the shifting shaft was bent also. That took a different lever and straightening the shaft to fix. Hope the little things work.
