JD 60 Oil Compartments?
Berto M
01-13-2005 14:16:54
How many oil compartments does a JD 60 have? Also where does one get to them? The ID Plate says it is a 1957, is this possible? It is an LP powered tractor with one wheel in front. Please help if you can.
buickanddeere
01-13-2005 18:33:24
 Re: JD 60 Oil Compartments? in reply to Berto M, 01-13-2005 14:16:54
Last rowcrop LP 60 was shipped on July 20th 1956 to Memphis TN at the tail end of the 1956 production year. 1-800-522-7448 gets the real JD operators manual, service and parts manuals cheap. Lucky you. I've been looking for a while to find a running 60LP. PS,engine,trans,hydraulic and pto. More than one place to drain the transmission. I guess you could count the out bearings on the rear axles too. If it was a rollo-matic front axle, there is a gear box in there too.
Berto
01-14-2005 11:51:41
 Re: JD 60 Oil Compartments? in reply to buickanddeere, 01-13-2005 18:33:24
Thanks, so the ps engine trans hydraulic and pto are all different compartments?
buickanddeere
01-14-2005 15:55:15
 Re: JD 60 Oil Compartments? in reply to Berto, 01-14-2005 11:51:41
Yes. Hyguard hydraulic oil works fine in the wet pto clutch case and in the hydraulics. Make certain the pto clutch/gear case isn't full of trans lube or stink like sulphur. Gear lube ruins the clutch friction material. Clooney has some very informative photos on this topic here that a search should find. The rear axle casting has to be unbolted of the back of the transmission case to access a seal. He also suggested marine version of GL4 for underwater gear boxes to be used in the transmission. It's formulated not to break down into something corrosive to brass/bronze should condensation get in there.
buickanddeere
01-13-2005 18:36:04
 PS in reply to buickanddeere, 01-13-2005 18:33:24
Forgot about the lube oil in the distubuter above the bronze bushing.
