430 electronic ignition
Hayfarmer
01-12-2005 20:34:12
I converted my 430 to electronic ignition a short time back. Increased the plug gap to .035. This tractor usually needs choke even in good weather to start. Since I put on the electronic ignition I don't need the choke even with weather in the 20s and 30s. Tends to over choke if I use it. Anyone else have this happen from the conversion?
Clooney
01-13-2005 12:54:24
 Re: 430 electronic ignition in reply to Hayfarmer, 01-12-2005 20:34:12
Hayfarmer, it's probably not due to the electronic part of the conversion..
The .035� plug gap sure didn�t hurt the cold engine operation & more than likely you have the ignition timing in a different place..
Get the tractor warm then do a fresh carb adjustment,, that should allow you to lean the idle mixture out some & then use more choke on starting.. Remember that idle needle is an air adjustment jet so works backwards (in is rich)..
If the tractor is left outside look for ice in the air cleaner as that will really richen it up�
Clooney
John T
01-13-2005 07:42:04
Hayframer, I cant answer your question about a similar experience regarding the choking, but if you also installed a high performance high voltage coil along with that new elec switch (which I strongly recommend) I would try an even wider plug gap (assuming you have good plug wires or ones to match any high pefrformance coil) and see what happens????? ????? ????? Part of the advantages offered by an elec switch and high energy coil are the ability to arc jump a wider plug gap with more energy (than a convrentional ignition) to get a wider fatter (more surface area) spark to better ignite the fuel.
John T
Bguy
01-13-2005 07:22:06
Did you convert to 12 volt? I am working on a 420 now and I might go electronic but I don"t want to change to 12 volt.
buickanddeere
01-13-2005 12:14:47
 Re: 430 electronic ignition in reply to Bguy, 01-13-2005 07:22:06
Pertronics makes a 6V electronic system model 1123 and add a P on the end for positive ground so #1123p. They have a matching rooting tootin coil too.
Problem with 6V systems is voltage drop from undersized batteries, high resistance connections and discount bin battery cables. A 12V conversion just masks the symptoms of the problems.
