2040 diesel with 143 loader questions
Tom in Mo.
01-12-2005 16:44:58
I have several questions. This tractor is for sale locally and need info. Is this a Yanmar built Deere? Is this a good all around machine as far as longevity? It's advertised for $11,000. plus and says it's a '78. This seems WAY overpriced to me; am I wrong? Is this a heavy duty loader suitable for round bales? Thanks for any and all info.
billde
01-13-2005 05:35:07
 Re: 2040 diesel with 143 loader questions in reply to Tom in Mo., 01-12-2005 16:44:58
there should be a serial plate on the tractor and on the engine. This will tell you if it's U.S., German, or Spanish made. Fantastic little tractor,but alittle small for what you're going to do unless you stay on level ground. The price is at the top end, but if it's real nice it will bring that much. For that much money you could have a nice 4020 with a loader and bale fork and move 2 at a time.
Indydirtfarmer
01-13-2005 03:13:43
That tractor was made in Manhiem Germany. If it's in decent shape, and the loader is in good working order, it will easily bring that much. Maybe that's at the high end of the price range, but if you don't buy it, someone else will. Can't fault a seller for getting the full price out of their tractor. They are good little tractors. The 2440 it's being compared to was made in Dubuque Iowa, untill 1980 when production of the 2440 and 2640 were moved to Manhiem also. Don't give that a second thought. They are well built tractors....
Pete/ME
01-13-2005 03:12:21
Pretty sure it's a Mannheim built machine. (One size smaller than my 2240.) Eleven grand would be O.K. if it was cherry. Would probably lift small round bales, but if you're moving a lot of hay or use the large bales, you should consider a larger machine.
GNB
01-12-2005 18:28:17
I think that it is overpriced. Go to machinarylink.com and look at the used tractor guide and it is usually close. THe tractor would have to be a very low houred machine to go for that price. This model is not foreign according to my research. Dont know how well this model will hold up. I personally have a 2440 and love it. The 2040 was made about the same years that the 2440 was made and would assume the 2040 would be a good machine. Hope this helps.
GNB
