1010 Ignition
BirchbrookFarm
01-12-2005 15:12:09
I have a 1010C bulldozer. The ignition switch needs to be replaced. The dealer told me that there was an external pick-up resistor installed in the replacement kit. I was wondering if I convert to electronic ignition would this eliminate the need for a pick-up resistor. There is about a $60 difference between the kit and the switch alone. I wouldn"t mind spending the extra cost for the electonic ignition. Also, I would like any input on the brands on the electronic ignition.
Thanks Mike
jdemaris
01-12-2005 20:22:23
 Re: 1010 Ignition in reply to BirchbrookFarm, 01-12-2005 15:12:09
1010s and 2010s originally had the ignition resistor built into the ignition switch. Then, during the late 70s Deere came out with a kit for ignition switch replacement that used an external resistor instead of in the switch. End result is the same, just a different way of doing it. We had trouble with all of them with premature ignition points wear - but moreso with the Prestolite than the Delco. Deere probably lost their supplier for the first switches. I assume you realize that the 1010s and 2010s were equipped with 6 volt coils, not 12 volt even though the system is 12 volts. Seems to make a difference in very cold weather, I don't know why the extra spark potential is needed. Perphaps the later Deere gas engines have poorly designed combustion chambers. At the Deere dealership with tried puting 12 volt coils on several 1010s, 2010s, 2020s, etc. They all ran fine but did not seem to start as well in extreme cold weather. Can't call it a scientific study though. But, considering that a 12 volt systems cranks at around 9 volts, it's obvious that a 6 volt coil can put out more spark than a 12 volt when operating on said 9 volts. From what I've seen and read, almost all the electronic ignition systems allow you to eliminate the ignition resistor. It was basically just put there to cut down the current going through the points to make them last longer. If you go that route, you won't have any points to worry about so I assume no need or necessity for the resistor.
John T
01-12-2005 17:11:13
Birch, I dont know beans about a 1010, and is that onboard switch resistor an "Ignition Ballast" or some sore of a "light dimming ballast" (if the switch is a ignition/light combo).
Regardless, if you check with Pertronix or Genessee (elec ignition makers) Im sure they can fix you up with a high performance 12 volt coil and electronic distributor switch (to replace points) that doesnt need or use any Ignition Ballast whatsoever. BE SURE N MATCH THE SWITCH WITH YOUR GROUND, POS OR NEG. I think they can furnish you with a full 12 volt system that needs no ballast and if so, they wire ahead of (the hot switched 12 volt feed) any ballast anyway.
On 12 volt tractors that used a 6 volt coil, the purpose of the ballast was to drop approx 6 volts leavign 6 across a 6 volt coil. Many then had a start by pass system/circuit which fed full batterY voltage to the coil ONLY WHEN CRANKING. I think most elec systems on 12 volt tractors use full 12 volt rated coils and dont even mess with any ballast, but Pertronix or Genessee cna answer all your concerns.
John T in Indiana
Clooney
01-12-2005 17:25:03
 Re: 1010 Ignition in reply to John T, 01-12-2005 17:11:13
John, some of those 1010's place the ign ballast resistor right on the back of the ignition switch between 2 switch terminals so it does sound like he is talking about a ballast resistor..
Clooney
