Duane Larson, spark plugs
Will P
01-12-2005 15:02:40
Well, all this talk lately of spark plugs has me wanting answers to some questions.
1. glazed insulators, what sizes are still available. Does anyone still make them?
I have a 43A, 43B, 49 and 51G. So I would be looking for plugs for them.
2. Resistor and non resistor plugs. Which one is better? Or for what application is each one best for?
I run 386's in my 43B which is a worker. But sometimes will foul them out just puttering around. 3116's? 388's? I don't have ANY luck with Champions. Never tried AC's
Thanks for the info,
Will P
Duane Larson
01-13-2005 06:14:07
 Re: Duane Larson, spark plugs in reply to Will P, 01-12-2005 15:02:40
Well, Thanks Clooney and Will P - glad to help. I also meant to share the following but it got too late, so here goes. When JD introduced their gasoline burning engines in 1947, they did what conventional wisdom said - use a colder plug than used for fuel-burning engines. They started with a Champion 6Com, and (skipping info in the Field Service Bulletins and other bulletins,) by November 1949 they had so many complaints related to gasoline/plug issues that they had designed an optional (hotter) manifold for gasoline, and gone from the cold 6Com plug to the AC88L Com plug because Champion did not make a plug hot enough (Champion got busy and developed the 10Com64 plug with a heat rating equivalent to the 88L, but took about 6 months).
So, it would appear that Deere initially had a rather poor understanding of gasoline burning in their Waterloo tractor engines, including the spark plugs. I am not aware of such a change in plugs in the Dubuque gasoline burning engines.
Will P
01-13-2005 15:00:45
 Re: Duane Larson, spark plugs in reply to Duane Larson, 01-13-2005 06:14:07
Thanks again Duane. I have printed it all out for future reference.
Just a few questions.
Autolite 386 = 3116
or
Autolite 388 = 3116
What part number is the hotter 4 digit non resistor plug?
Thanks again,
Will P
Duane Larson
01-13-2005 19:15:42
 Re: Duane Larson, spark plugs in reply to Will P, 01-13-2005 15:00:45
Will P,
According to the Autolite heat range chart, the 3116 is listed as between the 388 and 386, but I believe the fact that it is a non-resistor plug would make it a better choice than the 388. Theoretically, of course. Lots of respected folks (John T, you listening?) have had fine experience with 388's and recommend them.
F-I-T
01-13-2005 13:36:45
Okay, so here's my small amount of spark plug trivia....
How did GM come up with the "AC" in AC-Delco?
No fair Clooney! You might have insider information!
F-I-T
Will P
01-13-2005 14:50:51
 Re: Duane Larson, spark plugs in reply to F-I-T, 01-13-2005 13:36:45
Albert Champion
F-I-T
01-13-2005 14:57:05
 Re: Duane Larson, spark plugs in reply to Will P, 01-13-2005 14:50:51
VERY GOOD!
The originator of the Champion line of plugs sold his interest except for his name to General Motors who used his initials on their continuing line of plugs produced on his old equipment.
Later he re-entered the industry with the Stranahan family of Toldeo as Champion Sparkplug.
Duane Larson
01-13-2005 19:32:12
 Re: Duane Larson, spark plugs in reply to F-I-T, 01-13-2005 14:57:05
Frank,
Well, not exactly. Albert went with Billy Durant to Detroit to make plugs for Buick (and ultimately GM) where they formed the Champion Ignition Company. As one can imagine, lots of confusion between Stranahan's Champion Spark Plug Company (who had the Ford contract) and Champion's Champion Ignition Company (with the GM contract). A lawsuit in 1922 resulted in Champion's company being renamed the AC Spark Plug company. He was very successful with his company, had some publications, and remained active in the AC plug company until October 19, 1927 when he died "under suspicious circumstances" while in Paris. There are rumors of a romantic triangle involving his second wife and a prize fighter..... .
The whole story is an interesting one but much too long to relate here. As an aside, a relative of the Stranahan's, George Stranahan, was a physics prof at Michigan State Univ when Nancy and I were there, and he used to give free Champion spark plugs to all us grad students to tune up our cars. Neat guy!
Dave Langstone
01-20-2006 20:14:06
 Re: Duane Larson, spark plugs in reply to Duane Larson, 01-13-2005 19:32:12
Duane
I've been searching the web for info about the origin of Champion Spark Plugs, specifically what the disagreement was between Albert Champion and his investors prior to leaving his company and teaming up with Durant at GM. Was his dispute with the the Stranahans or did the Stranahans pick up the company some time later? Is this chronicled somewhere? You seem to have more information on this subject than is available elsewhere on the web.
I have a friend who used to be president of Champion Spark Plugs in Canada. He dealt with the Stranahans regularly but never was filled in on the details of the company's origin. He and I would appreciate anything you can provide on the subject.
Thanks
Dave Langstone
F-I-T
01-14-2005 18:50:31
Well, heck, I knew I'd muff the details. THe old Stranahan estate was down on Collingwood Blvd in Toledo near where I first went to college. In its day, it must have been quite an area.
Duane Larson
01-14-2005 19:50:53
 Re: Duane Larson, spark plugs in reply to F-I-T, 01-14-2005 18:50:31
Frank,
Well, I'm surprised you knew AC = Albert Champion - very few folks know that bit of trivia.
Duane Larson
01-12-2005 20:22:33
Will P,
I am presently under the opinion, based on observation, that plugs with glazed porcelain tips are no longer being made, at least by the traditional plug companies. For instance, the Champion 3X was "the" Ford Model A plug and when it was being made it had a glazed nose. Champion started remaking batches of them several years ago, and they do not have glazed noses, based on my observation of both old and new 3X plugs. I looked at a bunch of new plugs tonight and none had glazed noses.
However, the Champion 7/8"-18 thread 2ComL 2 piece plugs (made until about 1961) had glazed noses. The workhorse 18mm plug used in styled JDs from '38 to about '47 was the 2 piece Champion 8ComC, and it also had a glazed nose. The other supplier to JD was Edison Splitdorf, and its 7/8-18 competitor to the 2ComL plug was the 2 piece X46 and it had a glazed nose. The ES 18mm plug competing with the 8ComC was the Z19, and it had a glazed nose. There seems to be a correlation in time with the introduction of the gasoline burning engine in 1947 JDs and the demise of the glazed nose plug. AC began supplying plugs (again) to JD about 1948 (notes are in the house) and their plugs don't seem to have glazed noses, nor do Autolite plugs of that era. A long answer to your glazed nose question, but this may help answer other questions. Champion 2ComL and 8ComC plugs are still available from folks like Don McKinsey who deal in NOS plugs. NOTE that the Champion 8Com (a 1 piece plug) IS NOT the same plug as the 8ComC! A Champion engineering manual notes that the 8ComC was associated with JD use, implying limited use elsewhere.
So, I don't think any of the main-line plug makers make glazed plugs anymore.
Your 43 A and B would have come with 18mm 8ComC or Z19 plugs, both 2 piece take aparts and both with glazed noses. I don't have my plug handout here in the shop, so will have to reply to your other tractors later.
Resistor vs non-resistor plugs -
I can't think of a use for resistor plugs in our 2 cylinder tractors, unless the spark plug noise interferes with a mounted radio. Resistor plugs were introduced (Champion started using them in 1931, for example) to reduce rf interference with the "new concept" of car radios. Any resistor in series with the center electrode in an old "lower voltage - higher current" magneto system would result in some voltage drop across the resistor that does us no good. 386 and 388 are both resistor plugs (I measure about 6.8kohm resistance from the top to the tip), while the 3116 is not, but it's electrodes are somewhat lighter in construction. I doubt this would be an issue with plug life the way we typically use our old tractors.
I view spark plugs as a "messenger" who should not be shot over their condition, but paid attention to. Studying the end of a plug gives hints about what is going on in the engine. Gas fouling leads to a sooty like material and suggests running too rich, an oily deposit suggests oil burning, etc. I don't recall pulling a plug from a JD and thinking "this plug has been running too hot, I need a colder plug". For our typical uses, putting in the hottest plug that will fit will help accomodate some engine problems.
Man, I gave a whole seminar on spark plugs at the 2002 Gathering of the Green, and am on my way to repeating it here, which is not my intent. I use old 2 piece glazed nose plugs in my tractors (in general) because they are so easy to take apart and clean.
Hope this meandering, long comment answers some of your questions and helps somehow.
Will P
01-13-2005 04:31:31
 Re: Duane Larson, spark plugs in reply to Duane Larson, 01-12-2005 20:22:33
Duane, thanks for all the info. I knew you were the one that would have the answers.
Will P
Clooney
01-13-2005 03:16:51
Duane, nice piece here (very informative).. Now dip your fingers in a glass of cold water to cool them from all that key board friction..
Clooney
Duane Larson
01-12-2005 19:42:34
test
jgc
01-12-2005 16:04:39
I've just been "putting" around on my "D". Clooney suggested a hot plug which has worked out well for me. In my area, Champions are about $15 each and a similar Autolite was $3.50 each (Canadian dollars). I like the Autolites because the porcelin sticks out of the metal further and they don't seem to load up with deposits as quickly.
My $.01 worth.
JGC
