4840 front light kit
JDBert
01-12-2005 14:44:00
Does anybody know where to get the light kits that go in the front hood, like the 50 series had, that converts 30 and 40 series? Does deere sell these or is it someone else.
AJM
01-12-2005 18:53:27
 Re: 4840 front light kit in reply to JDBert, 01-12-2005 14:44:00
Last year I tried to piece together a kit for my 4640 like 960 said, only to find the shape of the fule tank wont let the lights set back far enough. Deere mechanic told me only way to make it work was cut out part of tank and re-shape or take a BFH and dent in the front of the tank. I opted to not install lights. Mechanic said 4840 and 4640 both req. the same operation. 4440 ,4240, and 4040 are not a problem as the tanks are different. If you can find an easier way let me know as I would still like to add 55 serise lights. AJM
Indydirtfarmer
01-12-2005 14:54:22
That takes more than a "light kit". You'll need to use the 50 series hood also. You can get it from John Deere, but hang on to your wallet!
JDBert
01-12-2005 15:01:19
 Re: 4840 front light kit in reply to Indydirtfarmer, 01-12-2005 14:54:22
The kit I've seen before you take the fiberglass nose off and cut it in. I've also seen the ones like your talking about and I know what you mean about the $ figure!!
Indydirtfarmer
01-12-2005 15:48:24
 Re: 4840 front light kit in reply to JDBert, 01-12-2005 15:01:19
Actually, that's what I MEANT to say. The NOSE CONE is what you would replace. The 50 series hood has a grab handle to help with refueling.
960
01-12-2005 17:17:34
 Re: 4840 front light kit in reply to Indydirtfarmer, 01-12-2005 15:48:24
Four years ago I installed such factory parts on a 4440 and the parts bill was $325. Each item then was purchased separate from 50 series parts book. Take into count parts inflation your best guess. I do not know if a kit was made avail. from the Dress up a Deere program.
