JD 2020 - condensor problem
George Pond
01-12-2005 08:10:17
I seem to have a problem with distributor condensors failing prematurely. The tractor will
run badly, miss, hard to start, have no power, etc. and when I replace the condensor it runs
like a top. This happens about every 6-8 months.
I was wondering if anyone else has had this problem and what was done to correct it.
Thanks
jdemaris
01-12-2005 20:39:21
 Re: JD 2020 - condensor problem in reply to George Pond, 01-12-2005 08:10:17
The capacitor will usually last a long time and die slowly. As it goes bad, it loses capacitance, and when that happens the points arc and burn out a little quicker than usual. That's not to say there can't be a totally bad capacitor once in awhile with an intermittent short, but that's unusual. You ought to check it on a capacitance meter next time you have trouble and see if it's truly your problem. From the symptoms you describe, I'b be more likely to suspect a bad resistor or insulator in the distributor, or perhaps the wrong coil. 12 volt coils don't work well in 2020s if the original wiring is intact. It's supposed to have a 6 volt coil. After stating all this, I realize what I say matters little if your tractor runs fine for six months after replacing the capacitor. If that is indeed the case, seems either the capacitor IS bad, or you're stirring up bad contacts when replacing it, and making them work again, for awhile.
Clooney
01-12-2005 17:10:56
George, those condensers are pretty durable & about as reliable as a paper clip. Any chance you are using the wrong condenser retaining clamp & squeezing the condenser shell too tight?
If the wire isn�t getting tugged on as the distributor operates & you aren�t getting a continuous spark arcing into the condenser case & burning a hole in it I would agree with Gerald in that you are getting some bad parts..
Clooney
Gerald J.
01-12-2005 14:16:32
 Re: JD 2020 - condenser problem in reply to George Pond, 01-12-2005 08:10:17
Change your source of condensers. Sometimes a production run seems bad, as often JD as not, so I've heard.
It might be of benefit to paint the insulator with some good insulating and waterproofing varnish like Glyptal to keep moisture out for sure.
Gerald J.
BushogPapa
01-12-2005 18:32:52
 Re: JD 2020 - condenser problem in reply to Gerald J., 01-12-2005 14:16:32
Where can I find Glyptol..??
I have not found it for many years, here..
Ron..
Gerald J.
01-12-2005 20:16:32
 Re: JD 2020 - condenser problem in reply to BushogPapa, 01-12-2005 18:32:52
I think Glyptal is sold in small quantities by GC. Its their part number 10-9002 according to my 2003 Allied catalog. Here its described as Red Insulating Varnish Alkyd based... $6.71 for 2 ounces. Local electronic distributors that carry GC/Waldom should have a better price than Allied.
It ought to be a staple yet in good motor winding shops.
Gerald J.
