Equiv to Deere 303 hyd fluid
Jim Presley
01-12-2005 07:57:25
Can someone tell me an equivalent to Deere 303 hydraulic fluid? Manual says that's what should be used in Trans / hyd system. Is 303 a light, medium, or heavy viscosity? The guys at the local Deere shop had no idea what Deere 303 was....
Thanks!
jim P
Boog
01-13-2005 06:28:15
 Re: Equiv to Deere 303 hyd fluid in reply to Jim Presley, 01-12-2005 07:57:25
I have seen 5-gallon buckets of stuff advertised as 303 equivalent at my 'Autozone.'
G/MAN
01-12-2005 13:31:56
Use John Deere Hy-Gard. That is what replaced the old 303 hydraulic oil, and it meets all former and current specs for hydraulic/transmission oils in JD tractors. At least for everything built since 1960 anyway. The Low-Viscosity Hy-Gard is intended for extremely cold temps and use in hydrostatic transmission systems.
buickanddeere
01-12-2005 12:02:08
Check Mother Deere's prices, sometimes she is even better.
old
01-12-2005 08:40:23
Don't know where you are but if you have an O'reallys auto parts store there they have 303 under there own name. If meets most tractor company specs.
Bob
01-12-2005 08:09:56
I believe 303 is equivalent to regular Deere hy-gard or "universal tractor fluid".
Deere also makes the lower-viscosity cold-weather hy-gard.
Here's a link for a non-OEM version, with specs.:
